Just googled for the osram number and it came back as a small bayonet 12V 6w lamp also know as a BA9s , then all you need is an LED version..Thanks for the link - I don't know??How do you know if that is the right size? Would need a UK supplier though.
The trick with lamps is to know what they are called in all markets, your osram is also known as a BA9 and a T4W and a 233, however as soon as you go LED you have to check how it looks and whether it will fit in the location the old one came out of and whether the reflector will still project the light in the desirable direction etc.Ahh, cheers Loz - you're better at this than me - could not get anything from the Osram number, I will check it out and see if a (cheaper!) eBayer has them...![]()
These fit . A push fit and work perfectly. Couldn't find anything cheaper when I was looking.Ahh, cheers Loz - you're better at this than me - could not get anything from the Osram number, I will check it out and see if a (cheaper!) eBayer has them...![]()
