Yes.Is the socket next to the 240v socket on the kitchen unit a standard 12v one these days?
On my 2009 Cali it was a hella socket and the adapter I had kept blowing the fuse so I don't use it any more
Sent from my Galaxy S6
............ the 2 pin socket at the base of the B pillar behind the passenger seat. This is the continental design and powered by an inverter off the leisure batteries and produces 230 volts AC. This is a low power supply, so will only be able to supply up to 150 Watts, so a laptop is about it. As the inverter switched on when you plug something in, don't leave a cable plugged in if you are not using it. This will drain the batteries quickly, to no benefit to you.
Alan
Which socket are you referring to?In my 2007 Cali this one appears to be exactly the same as the others. I can't really imagine using it as to me that's in 'the luggage area'.
I have a 2010 Facelift van and the socket beside the 13Amp socket is a 12v "cigarette lighter' type.Is the socket next to the 240v socket on the kitchen unit a standard 12v one these days?
When I talked about the luggage area I meant the area behind the rear seat accessed via the tailgate. There is a 12volt socket near the floor on the right hand panel on my van. May not be there on your model though.In my 2007 Cali this one appears to be exactly the same as the others. I can't really imagine using it as to me that's in 'the luggage area'.
I use it for the 12v Tyre Pump I use for the Cali and bicycles etc:When I talked about the luggage area I meant the area behind the rear seat accessed via the tailgate. There is a 12volt socket near the floor on the right hand panel on my van. May not be there on your model though.
I haven't found a use for this one yet, but maybe sometime in the future.
Alan
Alan
I thought it was just me having problems with that 12v socket. I recently purchased a 12v battery tester which should in theory fit into all of the 12v sockets. When I attempted to use it, the 12v plug fitted all the sockets except the one behind the passenger seat. Why is it different to the others? Does it require some sort of adaptor? I am confused!After further poking about, I have a further question. The socket in the cup holder is 12 volt and works off the engine battery, the one right at the back is also 12 volt and takes the same kind of plug - cigarette lighter type. Very useful for my grand-daughter's phone charger when the Cali is being used as a 'spare room'.
The one I'm having problems with is the one behind the front passenger seat on the end of the cooker unit. The 12 volt one doesn't accept the same plug, it's much smaller diameter. So where can I get a plug for this and more importantly, what the dickens can I use it for?
If it's the Hella socket you have there (it's about half the diameter of a normal cigarette lighter socket) then the adapter I initially suggested to Bikergran will do the trickI thought it was just me having problems with that 12v socket. I recently purchased a 12v battery tester which should in theory fit into all of the 12v sockets. When I attempted to use it, the 12v plug fitted all the sockets except the one behind the passenger seat. Why is it different to the others? Does it require some sort of adaptor? I am confused!
Thanks 525107,If it's the Hella socket you have there (it's about half the diameter of a normal cigarette lighter socket) then the adapter I initially suggested to Bikergran will do the trick
Is there possibly something inside the socket that shouldn't be there? I once had to remove a Lego block from a customer's vehicle's cigarette lighter socketThanks 525107,
The socket that I have doesn't appear to be any smaller than the others but when I try to push the plug in it just resists all attempts to shove it home. I don't want to force it and I am now wondering if, for some reason, it has a slightly smaller internal diameter. If that is the case, why?
Your Hella adaptors plug seems to be a lot smaller than a standard 12v plug. Never the less I will take another look.
I don't think so. The van is brand new however I will check.Is there possibly something inside the socket that shouldn't be there? I once had to remove a Lego block from a customer's vehicle's cigarette lighter socket
I plug my Whale in to that one.When I talked about the luggage area I meant the area behind the rear seat accessed via the tailgate. There is a 12volt socket near the floor on the right hand panel on my van. May not be there on your model though.
Alan
I have just been out too take a closer look at the socket only to discover that you were right. I found this thing inside the socket.Is there possibly something inside the socket that shouldn't be there? I once had to remove a Lego block from a customer's vehicle's cigarette lighter socket
I thought that but the adaptor recommended above fits and works perfectly!Thanks 525107,
Whale?I plug my Whale in to that one.
Many thanks - bought and tested and working perfectly!Look at this on eBay:
https://www.ebay.co.uk/itm/201462789642
dual twin port USB 12 V universal car cigarette lighter charger adapter 2.1A
Plug this into the socket of the above adapter, you'll then have options to charge most devices that have a USB lead to charge
HahahaWhale?
