Sp0_0k
- Messages
- 1,247
- Vehicle
- T6 Beach 4Motion
Got thicker glass with acoustics package. Original ones still stick inside fine.Presume you don't have the laminated slightly thicker glass as I understand there is a a problem if you do.
Thanks. Got them on my order so will stick with them to avoid any issuesGot thicker glass with acoustics package. Original ones still stick inside fine.
Well I've installed the Dubflectas but I must say it was a bit of a chore. Driver went in without too much trouble but the passenger was having lots of troubles with the safety mechanism throwing wobblys.
Eventually got the passenger side window up and left it to settle. If I need to replace I'm going with stick-on ones from VW. Dislike the way the windows seems to "bend" into place.
No problem with the Dubreflecta ones as long as you follow the instructions.
Have you got the single glass front windows or Double Glazed? I have the single. I followed the instructions but also used Silicon spray on the rubber seal all around the window opening on installation as I had had problems you described on another vehicle some years ago when fitting ClimAir deflectors. Also make sure the metal clips are pushed well up into the channel.Followed the instructions to the letter! Still had problems with the passenger side. Window is closed now but if problems occur they will be binned. I'll take a look at the Climair ones if needed thanks @briwy
I've just spoken to the dealer to see if so can order the original VW T6 ones that aren't stick on but go into the window channel - he has told me that as far as they are aware they can only get the stick on ones? Does anyone have a part number of reference number that I can quote?
Thanks,
Jez
Here it is. However, for the reasons explained before I wouldn't recommend them. Plus they are too expensive.Hi Pablo,
Thanks for the offer but aid went for the Dubflectas in the end as couldn't get the part number - really pleased with them though so no harm done.
Thanks again anyway - if you've got it then would be good to post it for anyone else looking who finds this post.
