Amarillo
Tom
I have edited the summary to reflect people's comments and experiences.My t5 charges the leisure battery and trickles the engine battery.
Actually I think it's indeed only the leisure battery, but as the Coast/Ocean have 2 leisure batteries, that could have caused the confusion. It charges both of them if there are two or one of them if there is only one. Because the feature has the same feature code for Beach/Ocean/Coast the description might have led some to believe it trickle charges the engine. Unless someone really measured voltage increase on the main battery after plugging in the hookup.So this line, "230-V supply with charging feature for vehicle batteries" listed in the standard features of the online configurator should be, "230-V supply with charging feature for vehicle leisure battery". If so, it is very sloppy of VW to make this mistake.
Don't want to add to the confusion, but I still think my European T5 beach MY15 with hookup does not seem to have a charger at all. I've looked everywhere. And when measuring voltages of the batteries they stay the same even after hours on hookup. And I've checked the circuit breaker and every fuse. And I'm not the only one.
You also have a T5 beach? Do you know where this charger is located?The trickle charge on the engine battery is just that - very slow. It will bring the voltage of the battery up but takes days not hours. I've checked with a multimeter.
i would ask VW as mine broke and needed replacing - it worked for a while then showed no voltage increase on batteries and garage said it was bust and replaced it. All good now
