Cali-61-180-SE
- Messages
- 172
first think you have to check Fuse is ok or not. most of the time broken fuse is the problem .
Encouraged by all the helpful advice on this thread I decided to tackle my similar issue of no water.
It was an increasingly intermittent problem that developed into zero water but ended up with a very simple process of cleaning the contact points in the micro switch of the tap with fine sandpaper.
Testing the pump first then other components and voltage etc., I was confused when my multi-meter’s audible continuity test would indicate there was contact and disconnect in the micro switch of the tap. However, for some reason the switch wouldn’t conduct the 12V when the contacts were closed. A final attempt to clean the points with sandpaper seems to have done the trick. I don’t know enough about electrics to compare continuity tests with an ability to carry voltage, if anyone else has advice on that, it’d be much appreciated.
I have now reassembled the tap etc. but thought I’d post a couple of pictures of the process to access the micro-switch as it can be done in situ. I would suggest taking out the fuse before starting.
Gently ease the tap handle off by inserting a screwdriver and levering the right. This exposes the micro switch and in the picture I have inserted a small piece of sand paper and carefully used this on both sides of the contact.
View attachment 16461 View attachment 16462 View attachment 16463
After a bit of trial and error with a pump that was going "intermittent", I have found that keeping the pump wet when the van is not is use will keep it running sweet. I just flush the tank, before I use it, and leave a small amount in the bottom of the tank when I am done.
Yes, we can have a copy on forum and copy in downloads for people to print out.
I'll try that tomorrow. Is the connector easy to find?What happens if you short cut the two pins in the electric connector under the sink (the wiring to the tap)..?
No water in my kitchen tap..!
5 amp fuse is ok.
Removed the pump and hooked it up to a 12 v supply and it worked. Water is coming out of the tap.
Measured the bare cabels coming from the tap (with tap started)(without the pump connected) and read 12 volt current.
Reconnected everything again (cabels from tap connected to the pump), but the pump isn't working. Now I measure only 0,8 volt...! The tap makes a click when I turn it on.
What is going on here?
(I have noticed the last months that the tap water is loosing pressure...and now no water at all).
Yes, it is easy to find. Right under the sink and the tap. If the pump start pumping water to the sink when you short cut the two pins, then there is still a problem with the micro switch. Clean it again, and make sure there is good contact. You can often read 12 V but as soon as the pum
Yes, it is easy to find. Right under the sink and the tap. If the pump start pumping water to the sink when you short cut the two pins, then there is still a problem with the micro switch. Clean it again, and make sure there is good contact. You can often read 12 V but as soon as the pump engage /consuming amps the V will drop...which means the micro switch acting like a bottle neck...
Thanks for the advice. That would make sense. When I tested the connection earlier today with the pump attached the voltage was much lower, which supports this.
I was just reading your earlier post and you seemed to have the same issue. I was about to ask you what the solution was in the end. I guess it was cleaning the microswitch. Thanks again.
First thing I would do is take the pump out and test it's working .
The wires will unclip then you need to take the top off water tank pull pump out . You could try turning the little bit on bottom of pump might get it going . Hardest bit is getting lid off you need to make a tool. I used a length of 2 x 1and to bolts to get on the fins of the lid . There is a very good description on here somewhere try the search button.Is that easy enough to do Jeff, re wiring and connections?
