AlanC
Traveling
Liz and I are currently touring West Scotland and usually try to cook outside as we don't like the residual smell of cooking in the van.
A couple of nights ago, at Lock Lomond, we used the 2 burner hob on a table outside as usual.
When I came to removing the regulator from the top of the 907 Gaz bottle, the valve in the top didn't close properly and leaked butane at a high pressure. I quickly stuffed the carry handle end down the valve seat to reset the ball valve hoping to clear whatever was jamming the ball valve and the hissing stopped, the handle was screwed back on and all was well. As the next day was expected to be raining all day I put the hob and bottle away and thought no more of it.
We sleep on the bottom bed and in the morning both of us felt light headed, slightly dizzy and unwell. Given we had only had one glass of scotch each and no wine with the meal, clearly alcohol was not the culprit - this time.
As we were both feeling ill, I got to thinking about the Gaz bottle which was stored in a Really Useful Box under the bed board and below our heads, and realised that the 907 valve may still be leaking slightly and filling the storage box till it spilled over the top.
The Gaz bottle immediately went outside and as it was low anyway, I swapped if for a new refill later in the morning leaving the old one in the open storage cage a distance from us.
It took a while for us to feel better, but with the tailgate and the door open lots of fresh Scottish air did the trick despite the rain.
I am now trying to work out how to carry a spare Gaz bottle in the van with suitable drain ventilation so that this won't ever happen again.
A Cali doesn't have an 'A' frame to clamp it to and the water bottle will only take one 907 bottle...but would it take 2 x 904 bottles stacked one on top of the other? Would be a pain to use each time, but we would be guaranteed to wake up each day...
Happily still alive, for now!
Alan
Alan
