That looks fine.Hi
I just fitted my Brandrup airvents for T5 T6 cali`s. I can't get mine to fit straight, or is this normal. Works fine, but all the photos Ive seen show them lining up square with the top of the window. No big deal, I just wondered if I did something wrong. Thanks.
Yes same things on both sides.When I had some they lined up OK.
You need to make sure that they are fitted correctly, by hand, at the top before closing the window.
Did you get the same misalignment on both sides?
I have just tried again and there is no way I can get it straight. Im away for the van now Ill check the gap tomorrow.If you open the window to 1 cm below the vent is the top gap parallel, window top edge to vent bottom edge?
