What is the problem? Is my Cali too hot?
yuchili
yuchili
Taipei, Taiwan
T6 Ocean 150 4Motion
Did anyone have the same problem? How did you solve it?
(in the upper right corner, a flashing sign of a car and a thermometer)
I mean the problem is a flashing sign of a car and a thermometer in the upper right corner,
  • Disagree
Reactions: Les
When a symbol flashes it normally indicates a fault of that item, perhaps you have a faulty temperature sensor? Will it display the temperature?
our 1st van never showed the temperature from new and just the icon you have on your picture it turned out there was an issue with the temp sensor
Mine suffered that on delivery - dealer said it was something to do with the fridge (they had no idea what it was) and sent me on my way but after researching on here it was the auxiliary temp sensor - was faulty and sorted under warranty.
Check out the diagnostic codes stored as mentioned above.
Does anyone know where the auxiliary temp sensor is located and part no.
I need to replace mine and wondering if it's a diy job or dealer .
