soulstyledevon
Kennycalifornia
- Messages
- 6,517
- Vehicle
- Cali now sold
Not on mine.So the awning rattles.....
Having a look, I’m sure my old one had a long piece of cushion around the centre of the clip. See pic.
Could one of you guys check yours and see if you have it please...???
Was something like this before
Not on mine.
No, no padding. Occasionally I get a rattle, normally after I’ve wound up the awning on-site. I just wind it out a little and re-wind. No more rattle until next use of awning.Anywhere down the length of the bar Welshgas...?
Im positive thats whats rattling and I'm sure the old van had this piece of cushion glued in place. Never had a rattle on the old van![]()
I went crazy with the furniture pads at the weekend. No good. The wires in the arm are the only possible source and my previous awning was replaced due to the same noise by VW. (Known issue?)
I'll unwind it at lunchtime and wind it back in.
You can start at one end of the awning with a light finger tap and work along the whole length of the awning to create the noise. Only stops in the middle of the awning.
My awning was replaced and rattled so placed some of those mushroom thingys on the legs which has helped . On the inner and upper face when stowedEar plugs?I have the Ikea felt furniture pads all over the place. Winding out and back at lunchtime helped. Needs a bit more of a poke but does still rattle.
It can only be the wires.
Yes I have also considered expanding foam
