pjm-84
- Messages
- 2,715
- Vehicle
- T5 SE 180
Found the source of the noise. Currently sitting under the extended awning and the front arm bracket hinge creaks badly in the wind.
Which one please?I used a special lock lubricant spray, similar to WD40, two months ago and it has been completely silent ever since.
Which one please?
Had the same issue took it to a Thule dealer he immediately new the problem installed x3 pieces of clear M3 vinyl or similar from Thule positioned each end and middle.Arghh found the old post and resurrected it.
The awning rattle is between the awning and the bracket on the van at the front. I've loosened it and put a business card to act as a shim and it cut about 70% of the noise out. The card is now well and truely knackered so the rattle is returning. Needs a plastic / isolating shim of some sort
