Loz
That indicates that the alarm(doors and Immobilizer) is active.Thanks. But what then is the flashing light on the button of the drivers door ?.I have that but no button on the B pillar.
Little red led by the pop up button in the door.What light was flashing ...?
Yes thats right.Little red led by the pop up button in the door.
You may find it is still alarmed withe deadlocks off. Try winding down a window, lock with a double press(deadlocks off) wait 30 seconds, then open the door by leaning in and pulling the insidehandle.With my car if I double check it's locked by clicking the fob nothing happens if it is already locked. However with my van, whenever you do the 2nd click it will turn the alarm off and take the deadlocks off. That means that if you're not sure you've locked your van when walking away you should always click to open it and then click once to fully lock it. Otherwise you'll just end up making it more unsafe if it was already locked! My van is rather older than many here (from 2006) so perhaps this is something VW has improved upon. Or maybe someone's about to explain how I've got it wrong?
Yeah that’s correct it stays that way until you switch in to red again (on)As long as the switch is showing yellow, that means the alarm is off, does it? (If I switch it to yellow, lock the van & then look through the window to check it's still yellow)
