E153 - no shore power symbol showin
Vwolder
Vwolder
Denmark
T4 PopTop
This one is driving me crazy.
Original charger. Seems to be working just fine. Charging is great.
Everything on my E153 control modul is working as well - except for the symbol showing that I am plouged in to 230v?
Any ideas??
I think we’ve been here before. I’ve a feeling it only shows when battery is fully charged.......on some versions
Did I just make that up? Not sure?
I think the manual says that it should come on as soon as it is hooked up.
I might have a problem withe the charger. I am only getting 13.0/13.1 volt and I think that I should be getting above 13.5 v.
It seems to be the temp sender in the battery compartment that is fooling the charger. When I unplug the G18 sender unit the charger goes crazy and gives me 15.2 V!!!
The g18 sender unit is giving me the right resistance (500 ohms/20 celsius) so i must be the charger unit. It would not be the first time as I understand :-/
Interesting.
My 93 Westy definitely had an mind of its own where the icon was concerned, even after I’d replaced the charger.
Aye it's the bar that goes off if not under load or something like that. I've seen far too many of the westy chargers go up in smoke recently. I swapped mine for the FraRon compatible unit for the westy screen. Works a treat and I don't worry about the van going up in smoke.
Sent from my ONEPLUS A5000 using Tapatalk
SOLVED
I had a talk with a great guy from Germany who fixes these old units.
I seems that my charger was swaped for a later but still original unit. That unit use another temp sensor with a different resistance. God that sorted and now it is working like a champ!
Have a nice sommer and happy camping
SOLVED
Name? Contact details?
Sounds like a good man to know.
this is a very old post, but I too would love the contact information for that Bodo repair fellow who helped you.
but of course that advertisement that had his contact information has disappeared.
did you happen to note a phone number or email address for him?
Peter in Canada
Any ideas??
SOLVED
Peter in Canada
