Sonas
Ive been following a thread about roof canvas getting trapped or torn when lowering the automatic roof. Are there similar issues with the manual roof for the Beach/Coast models, or is its just the same.
Sonas
Sonas
Different issues. Trapping the fabric in the fastening clip is the danger with the manual roof. Not so serious.Ive been following a thread about roof canvas getting trapped or torn when lowering the automatic roof. Are there similar issues with the manual roof for the Beach/Coast models, or is its just the same.
I once tried to lower the roof with the topper still in place - doh!It's almost idiot proof, but then we all having idiot moments that we come to regret.
That may all be true in theory but unless I'm mistaken, why do almost all of the posts featuring torn roof canvas, damaged roof mechanisms and twisted roofs etc seem to come from SE/Ocean owners? If I'm correct, this could be because most owners operate the roof mechanism by pressing the control button whilst sitting isolated from the action in one of the front seats. When the canvas gets trapped without the owner being aware, their continuing to press the button will cause the powerful electro/hydraulic mechanism to continue to cause damage. With the Beach you have to stick your head up above the roof bed to pull down on the closing bar. You can therefore see the state of the canvas and adjust it as the roof comes down. If any issues do occur then I suggest that unlike the powered system you as a human being might be better able to detect any resistance and probably see the problem occuring as well.Just as likely to damage the canvas on the Manual or Hydraulic roof if you don't pay attention and follow the instructions to the letter. " Sods " Law can also intervene.
The Hydraulic roof only moves when the button is pressed and the Manual only moves when you pull, so you are in control.
Possibly because there are more SE/Ocean Owners on the Forum than Beach Owners. Certainly the SE has been around longer than the Beach.That may all be true in theory but unless I'm mistaken, why do almost all of the posts featuring torn roof canvas, damaged roof mechanisms and twisted roofs etc seem to come from SE/Ocean owners? If I'm correct, this could be because most owners operate the roof mechanism by pressing the control button whilst sitting isolated from the action in one of the front seats. When the canvas gets trapped without the owner being aware, their continuing to press the button will cause the powerful electro/hydraulic mechanism to continue to cause damage. With the Beach you have to stick your head up above the roof bed to pull down on the closing bar. You can therefore see the state of the canvas and adjust it as the roof comes down. If any issues do occur then I suggest that unlike the powered system you as a human being might be better able to detect any resistance and probably see the problem occuring as well.
So to answer the OP's question, unless I am mistaken it would appear that you are less likely to experience the same issues with the manual roof on the Beach or the Coast. Just watch you don't trap the canvas in the roof catches though.
I agree, undoubtedly a factor. However, as far as I am able to recall I cannot remember reading many, if any torn canvas issues from Beach owners.Possibly because there are more SE/Ocean Owners on the Forum than Beach Owners. Certainly the SE has been around longer than the Beach.
Interesting. Having also had both versions I too found the electro/hydraulic roof easy to use but always felt that the potential for damage was greater than in the Beach that we also owned at the same time. You say it was less prone to damage, if you don't mind me asking what damage did you suffer with the manual version ?Had both and electric roof IMHO is much easier and less prone to damage. Finger on button, head in roof space facing rear and watch it come down. Finger off if wind or whatever causes an issue. Having said that I'd rather have a manual roof but with a decent clip system.
Hello Max-Felix,Hi Borris - I think as an example if you look at the old Westfalia Cali T4 roof for instance - pull a bar down and slide a lever across - done! Like so much on the Cali there are dozens of refinements VW could make to improve fit, fixtures, ergonomics etc across the kitchen unit, trim, control panel, socket placement, etc, of what is 99% a 15 year old design but they just don't seem interested..
I just found the back up buckles/webbing and afterthought design and fiddly, the main clips small, difficult to access, stiff and not user friendly, the rolling up of the canvas behind the straps a faff. Yes, it works but it could all be much better and simpler/quicker - it's extreme penny pinching too that they deny Beach owners a front window. I also think the Beach roof could benefit from some front braces or larger diameter gas struts.
I did not suffer damage in the Beach (although previous owner had holed it a couple of times by the front buckles) but sticking your head in the SE/Ocean roof space while watching it come down as you control it with no front clips to worry about has IMHO less potential for damage. The excess roof fabric also seems to control itself much better in the SE/Ocean.
As I say though if I was keeping a Cali/Beach for long term I'd go Beach, partly for the roof (but mainly for the layout).
If there was an after market option to fit a front window i would go for it too - in fact i love the big zipper options on the Swiss stuff where you can zip away the canvas and roll it up - that would be lovely on a starry night - or at an event where you can gain an elevated position ......... if the canvas can be dropped out easilly the zip option would be fairly straightforward if you had the kitYes, all valid points - if we all went on about improvements throughout the entire vehicle I think we'd be here all day - so much could be done!
The front window is really useful for quick extra light and ventilation and easier to access than the side ones. And when lying up top looking out the front it's a great view.
