Seat belt warning, Question.
United Kingdom
T5.1 se 180
Ok, if I don’t put my seat belt On I have a Red Warning Symbol on the Dashboard. But is there also an Audible Warning Sound as well?
I can’t remember if there is.
Yep, really annoying 'bong, bong, bong' and if you don't comply with ze rules after a short while you get 'DONG! DONG DONG!'...
Yes but it goes off after a fairly short while leaving just the light showing.
Mine seems to have stopped. Just the Dashboard light.
Clarista shows the Seat Belt Warning is enabled. So Disabled the Re-Enabled it so will see what happens when we next move.
Thanks all for jogging my memory.
Hi are you getting the ticking noise when operating the indicators ? The dash insert uses the same speaker for the seatbelt worming as it does for the indicators.
Thanks for that. Yes, the Indicators make a noise when activated. Will check the Seat Belt Warning tomorrow.
Indicators and Low Temperature sounds present. Seat Belt Warning Not, just the Dashboard Indicator On and goes Off when Seat Belt connected.
Another thing I’ve noticed Stop/Start has not worked with AirCon at 21c , or Off.
Fridge is On and I have a Towbar bike rack plugged in. Does Stop/Start stop working when a trailer is connected?
Everything else OK.
Everything else OK.
Hi no start stop will work with a a towbar conected. There is a long list of why it won’t work but basics are in dpf regen, low outside air temp, heater on max, seatbelt not conected, high use of consumers. So the seat belt and stop start maybe linked
Thanks for that. It was all working, well Stop/Start was before we left on this trip. We’ll see what happens when we get back and everything is Off.
My understanding is that stop/start doesn't work with tow bar electrics connected. Caravan or bike rack, it can't differentiate. We were told by VW Lancaster when we collected our Cali that stop/start would not work if electrics connected. That is certainly the case when we towed our caravan or when we connect our bike rack.
Interesting. Will check when the bike rack comes off.:thumb
Interesting. Could be a simple way to disable it then rather than playing about with relays etc that I had planned.
The other thing that is disabled, quite obviously, is the reversing sensors. I get a picture of an 'A' frame whether it is bike rack or caravan.
The rear fog lights are also disabled when something is plugged in.
Alan
Stop/start DOES work with trailer connected. At least it with our factory fitted towbar and electrics
Sent from my Moto G (5) Plus using Tapatalk
On our 2014 SE, plugging in the tow bar electrics disabled stop start.
On our 2018 Ocean, it doesn’t, so VW must have changed it.
Slightly off topic, if you have side scan, it’s disabled when tow bar electrics are plugged in. Annoyingly, it stays off when you unplug, and you have to re-enable manually.
Are they factory fitted, dealer fitted or did the dealer get somebody else to fit the electrics.
Whilst a low trailer probably wouldn't cause any problems if you are towing a caravan or a taller white trailer the glare of the fog lights reflecting of a near white surface would be very distracting.
On that basis it seems they should logically be disabled.
My bike rack has fog lights as did my caravan.
Sorry, I should have been clearer.
The rear fogs on the van are disabled when anything is plugged into the trailer socket. The rear fogs on the trailer, be it a bike rack or caravan, will function.
I have assumed that this is to prevent a very bright red glow in your rear view mirror reflected off the front of what ever you are towing. But suspect there is a more technical and possibly legal reason for this.
Alan
I would have thought so but if that is the case does that mean a lot of members of this site, and others are driving with illegal lighting to their vehicles?
Well can confirm that plugging into the Towbar electrics, factory fitted by VW, on a MY2015 SE disables Stop/Start and also Disables the Seat Belt Warning tone as well.
I can understand the Stop/Start, the electrics could be Charging a battery of running a Fridge in a Caravan, but cannot for the life of me understand why the Seat Belt Warning tone is disabled.
It makes absolutely no sense why it disables the seatbelt warning I will look at the wiring diagrams and tech info tomorrow. To try and work out why that is happening.
