I have exactly the same intermittent rattle. It sounds as if it's coming from the B pillar at right ear height. I've had the van for thirty months and in that time have tried everything to eliminate this noise.I have this very annoying "over the right shoulder" rattle and have proved its the door by driving with it in the fixed but open position on a back road and its totally silent. If you rattle the male spring loaded main-lock large prong on the door it makes the rattle that I can hear. Its spring loaded so this should stop when located in the female part on the van B-Pillar but there is still the noise when shut!. I tried putting pads in the top and bottom locators but no change.
It goes into VW on Tuesday to be be corrected but at least I can tell them exactly where its coming from. I will post VW fix here....
PS: Interestingly the rattle completely disappears at fast speed on Motorways etc.
Thanks for that input, i´m gonna replace mine now.Changed both top and bottom set of (male and female) guides, about £20 from VW main dealer, had to be ordered in, easy job to fit, solved the problem totally. Sanity returned to each journey
But mine has done it from new so the cause can't be worn parts. If these parts are the cause then they must either be defective or badly adjusted. The only other reason is simply bad design but if that was the case then all Calis would have the same rattle.Hi Guys,
My first post
See Boris earlier post #5 where he identifies the female door location guide. There is a male guide on the door also which located into the pillar female guid.
I had an intermittent rattle on a T5.1 2012, it used to drive me nuts, and is very distracting.
It was really difficult to pin point the exact area the noise was coming from, even when seated in the back, always appeared to be somewhere around the sliding door though . I tried adjusting the male and female parts, with initial success, noise stopped, then returned shortly after, then tied to pack the female part with grease and readjusted, again the problem went away for a few days but returned again, came to the conclusion that the female part must be worn.
I hope that helps
Here you are.Thanks for that input, i´m gonna replace mine now.
I just need the parts picture from welshgasso i can get them
ordered.
Have you tried putting the arm rest down? Had 2 Cali's now and both have had arm rests that rattle when up. First one took ages to diagnose, thought it was the sliding door, or the blind cables, or the awning, or.......but was actually the arm rest being up on the right hand side of the drivers seat. Adjusting the dial i.e. height setting or lowering the arm rest got rid of the rattle.But mine has done it from new so the cause can't be worn parts. If these parts are the cause then they must either be defective or badly adjusted. The only other reason is simply bad design but if that was the case then all Calis would have the same rattle.
Wow! Not heard of that one before. Might explain a problem I have on the passenger side. Will investigate. Thanks.Have you tried putting the arm rest down? Had 2 Cali's now and both have had arm rests that rattle when up. First one took ages to diagnose, thought it was the sliding door, or the blind cables, or the awning, or.......but was actually the arm rest being up on the right hand side of the drivers seat. Adjusting the dial i.e. height setting or lowering the arm rest got rid of the rattle.
Not on my iPad or Mac.Virus in that link Welsh Gas!
Thanks but it's not the arm rest. It's definitely coming from the B post around the area of the top seat belt fixing point.Have you tried putting the arm rest down? Had 2 Cali's now and both have had arm rests that rattle when up. First one took ages to diagnose, thought it was the sliding door, or the blind cables, or the awning, or.......but was actually the arm rest being up on the right hand side of the drivers seat. Adjusting the dial i.e. height setting or lowering the arm rest got rid of the rattle.
Can’t help you I’m afraid. Haven’t used Windows since Windows XP.If I open your link Norton Security pops up a WEB ATTACK....
