N
Neuon2003
If you want to keep the light out in the morning tick the blue bellows box. ...
It comes with a small hand pump made out of the same material as the mattress. If you Google “Megamat” you will find many glowing reviews and comments on the level of comfort that these provide. The SIM Duo 7.5 is virtually the same, the only differences being it is 7.5cm rather than 10cm thick and has tapered rather than boxed edges; this last point actually helps when closing the roof I think. It’s no exaggeration to say that I sleep as well, if not better, on this than on our expensive, ViSpring, pocket sprung mattress! If people are not familiar with a SIM (Self Inflating Mattress) then I should just say that they are not the same as a regular air bed since they have a foam and air core, which makes them more comfortable and much warmer (better insulating).
I can confirm it keeps torrential rain from the mattress and keeps it usefully darker and cooler on sunny mornings
That’s very helpful, many thanks. Time to break out the sewing machine, velcro and Kam snaps. The Brandrup Iso-top VI will be the best part of £550.00 with the optional front fly screenI bought 8m of "waterproof fabric 2oz breathable 7 colours" in black from EU Fabrics via Amazon. £32.
Sorry been away (in the van) and missed this. May not have been clear that we now just use the zonesleep, finding it comfortable. Outside of summer we also use the comfortz roof topper over the roof if heavy rain forecast or if very cold.Hi
Do you use zonesleep plus the topper?
Almost ready to press buy it now! One final question - when deflating so as to put the roof down, do you just undo the release valve and the mattress does the rest - or what?It comes with a small hand pump made out of the same material as the mattress. If you Google “Megamat” you will find many glowing reviews and comments on the level of comfort that these provide. The SIM Duo 7.5 is virtually the same, the only differences being it is 7.5cm rather than 10cm thick and has tapered rather than boxed edges; this last point actually helps when closing the roof I think. It’s no exaggeration to say that I sleep as well, if not better, on this than on our expensive, ViSpring, pocket sprung mattress! If people are not familiar with a SIM (Self Inflating Mattress) then I should just say that they are not the same as a regular air bed since they have a foam and air core, which makes them more comfortable and much warmer (better insulating).
You should have shares in this product....there are going to be hundreds of uncomfortable Cali owners rushing out to get one! ThanksIt comes with a small hand pump made out of the same material as the mattress. If you Google “Megamat” you will find many glowing reviews and comments on the level of comfort that these provide. The SIM Duo 7.5 is virtually the same, the only differences being it is 7.5cm rather than 10cm thick and has tapered rather than boxed edges; this last point actually helps when closing the roof I think. It’s no exaggeration to say that I sleep as well, if not better, on this than on our expensive, ViSpring, pocket sprung mattress! If people are not familiar with a SIM (Self Inflating Mattress) then I should just say that they are not the same as a regular air bed since they have a foam and air core, which makes them more comfortable and much warmer (better insulating).
Many thanks in advance - looking forward to a good night's sleep!
Thanks again!Sorry for the slow reply! I do tend to get up in the roof and roll around on it a bit to get the air out... but you would probably get away without doing this. We were away in the van last weekend so I took a picture of the deflated mattress in the roof. Note that it had been fully deflated and packed away prior to the pic... so it generally looks a bit more inflated than this when the roof goes down after a nights sleep.
After trying a Zonesleep topper on the standard mattress we replaced both with an Exped SIM Duo 7.5... supremely comfortable and you can let the air out and leave in the roof when lowered.
