2into1
Née T4WFA. Now running 2006 LHD T5 SE 130 Manual
We get plenty of threads asking why T6s often imitate a 'hovercraft' when you stop and park up. We know it happens when you stop the engine part way through a DPF regeneration.
But do we know what is actually happening when all those fans are whirring and heat blasting from underneath?
Is it using fuel as I wander off with the keys in my pocket?
Is it just using 12v to power the fans to cool down the process that was already underway?
- am I doing 'harm / wear' each time it happens?
I'm particularly annoyed that the 2(?) hourly forced regeneration always seems to having terrible timing. Today it again chose to start a regen just as I returned from a long run. It did its hovercraft impression as I nipped into Tesco before arriving home. It did it again as I arrived home. It will do it again tomorrow when I drive 4 miles to yoga, and probably again as I return.
I'll then be back to longer drives, free from re gens as it waits until I'm a mile away from home to start the next one.
I read that some users leave the engine running to allow it to finish the cycle, or drive a few extra miles to achieve the same - which rather negates the environmental goals of the system.
I think the more we know about the process, the better we can 'manage' it.
- so what is happening?
- how long does it take?
- does that timing depend on how its being driven?
- how long is it between regens?
- is that fixed or does better trips lengthen the intervals?
