Don’t go there, they fob you off with nitrogen stuff not real winter air.Does Kwik fit do winter air ?
Now quick fit told me you could mix air on the same axle as long as you don’t do it before sept 15th I won’t be going back thereI don’t know but ideally the same for both front and back tyres. Whatever you do don’t mix the air on an axle.
I’m also changing the air in the under sink cupboard merely as a precaution going into winter, I’ve just been told the portaloo that lives there was used a couple of weeks ago & has been brewing since...
Most garages sell winter airThis is all new to me, where do I purchase winter air from please ?
Mt Blanc would be your nearest source. at least half way up.This is all new to me, where do I purchase winter air from please ?
I think that only applies to all weather undies..If you turn the tyres inside out every so often it should even the wear out.
Next time you want any rimming doing you could just ask them.This is all new to me, where do I purchase winter air from please ?
O. M. G.Next time you want any rimming doing you could just ask them.
