Draining windshield washer fluid
clarinetbcn
clarinetbcn
T5.1 Beach 140
Barcelona, Spain
T5 Beach
Is there an easy way to drain the windshield washer fluid reservoir? I made the mistake of filling up with summer (non antifreeze) fluid in August and have used less that I thought, and now want to drain it out so it won't freeze. All comments re:summer/winter air welcome if you must...for those who don't know what that means, pour yourself a drink and use the search function, you won't regret it.
Get a coffee then pull the screen wash stalk for 5 minutes then add triple concentrate.
That's the obvious solution (!), but I'm not sure I have your confidence in the durability of the washer motor.
Pull the washer pipe off the jets to relieve motor pressure then as I previously stated :)
With a thin tube simply siphon it out. Don't swallow.
Put some IPA in the existing fluid, that’s all the anti freeze product added to screen wash is (isopropanol alcohol)
