Any 12v USB chargers left in a socket?Hi all. Currently sitting in my van. Everything is switched off (apart from the console) but the display is still saying -0.6A.
Any idea what could be drawing current?![]()
Control Panel normally 0.2a draw with screen on.control panel probably
can you switch the inverter off?Any 12v USB chargers left in a socket?
Check the Inverter is not on. Open the flap of the mains socket at the bottom of the passenger B Pillar.
Is there a LED light top left. If on and green in colour, I think, this indicate Inverter is powered up.
When you plug into the Inverter Socket then a small microswitch is depressed, L upper side , which switches the Inverter On. This switch can occasionally stick On.can you switch the inverter off?
Thanks! will have a look at the switch just to make sure. Had already fun tonight unplugging the fuse for the water pump.When you plug into the Inverter Socket then a small microswitch is depressed, L upper side , which switches the Inverter On. This switch can occasionally stick On.
The only other way to switch the Inverter Off is to remove its fuse. 30 amp fuse under front Passenger Seat.
Wow I didn't know that I leave my adaptor plugged in all the time and having just checked it I see the green light is on .....thanks for the tip it's now unplugged!When you plug into the Inverter Socket then a small microswitch is depressed, L upper side , which switches the Inverter On. This switch can occasionally stick On.
