john rensten
Hi Everyone, I know there's lots of threads but couldn't see what I'm after. So, i have a 2018 t6 beach and I want to use it over winter in the uk...I'm trying to find out more about the leisure battery. Firstly, the camping I do doesnt allow me to be plugged in/hooked up anywhere. What I'd like to do is basically run the heater for a period of time with the engine off but all I'm finding is that a. the lights stay on even though they are switched to off, which will obviously drain the main battery (?) and also, the heater doesnt warm up unless the engine is running...the scenario i'd hoped for would be that i'd pull up, run the heater on the leisure battery, overnight if needed, the heater would work as expected and that in the morning the main battery would be fine and a drive around would top the leisure battery up. Am I way off here? does the leisure battery need charging up by me hooking it up to the mains and in fact my leisure battery is flat (no warning lights visible) and does the heater actually do its job with the engine not running? many thanks in advance, john
