Birty
I need to replace a damaged blind on my T6 and assume I can buy one from VW parts..If I fit it myself, will I need any special trim tools etc or am I being stupid and just take to a dealer to fit?
£148 after club discount from VW SMG Tonbridge at mo...You can buy the bind £130
Part ordered from VW now..£148 .. Will have a look if it ever stops raining here, but also the trim kit looks comprehensive.. will source on ebay probable.. ta 4 pics!!Hello Birty,
Having just had the top half (window surround trim) of our T6 tailgate trim off, all I can say is it could be an easy job to do. I say could because I don't know how the bottom door card comes off. However, fiddling with mine gave me the opportunity to have a look at how the top half of that door card is constructed and attached.
The very top of the lower door card appears to be a separate moulding behind which is the blind. I am guessing that this can be removed without taking the whole door card off.
You can see the joint running along just above the interior light. Push it and you'll find that upper and lower are definately two separate mouldings. At each end edge of the lower trim section just below this joint is a plastic cover which I suspect hides a fixing of some description.
I'd be tempted to have a play with it as it looks as if the whole upper section is designed to be removed without the rest of the door card being disturbed. Probably done for ease of maintenance.
The fixings at each end where they join the upper tail gate window surround trim are simple enough. Here are some snaps I took when I took ours apart recently. They come apart very easily.
Finally, if you decide to have a go, get youself a set of plastic trim tools. They are very cheap, simple to use and are essential if you want to avoid causing any damage to delicate interior trim. There are lots for sale on Ebay.
By having a careful go yourself you could save yourself a lot of cash.
Please let us know how you get on as trim removal is always a bit of a mystery and finding out how to do this section would be another piece in the zigsaw. If you do decide to give it a go could you take pictures of the trim fixings etc.
Good luck
Like me, you probably won't need that many tools but a kit like mine isn't expensive at around £35 and you'll have it for any future jobs.Part ordered from VW now..£148 .. Will have a look if it ever stops raining here, but also the trim kit looks comprehensive.. will source on ebay probable.. ta 4 pics!!
Hello Alan,You'll need an extra pair of hands as the lower panel is a bit unwieldly to lift on and off.
I have done this a few times so not daunted now.
Take your time to find all the various plastic plus and torx screw fittings. Note that there are various sizes of screw and rivet.
I recommend that you completely remove the seat cover and associated trim, before attempting to remove the panel trim.
Dunno aint tried yetHello Alan,
Do you know if it's easy to remove the top of the lower tailgate door card?
Its gonna be fun... maybe over to you Mr VW !!I'm unclear which section you are referring to.
The lower plastic trim is one single U shaped item, with the blind mechanism held inside the upper portion.
From what I remember it looked as if the window blind mechanism is held in place with plastic lobs that appeared to have been melted in position.
Then the window blind mechanism has a bolt at either end that secures to a metal bracket attached to the tailgate. These bolts are normally hidden by a plastic bung at either side.
The top of the plastic trim has sprung clips holding it to the tailgate as those you have found in the upper trim.
The section of trim that I'm talking about is the upper section of the black plastic lower tailgate door card. You can clearly see it in the second photo in post 3 above.I'm unclear which section you are referring to.
Hi Boris, yes those are the bungs to access the torx screws that go through metal brackets on the tailgate, and then to the ends of the window blind mechanism.The section of trim that I'm talking about is the upper section of the black plastic lower tailgate door card. You can clearly see it in the second photo in post 3 above.
You have answered one question already though. The round plastic cover in the same photo must be the plastic bungs that you refer to in your post (9).
yes its a different design on the T6... 3 main components to be separated once removed... Might get chance to put it back together today but what a pig its been! Updates to follow.@Birty I took mine off to repair a leaking washer pipe, what a bugger of a job. I notice on your panel the blind looks to be a separate fitting to the rear panel, whereas on my cali the blind is what i call hot welded to the plastic panel see poor photo. the blind (top of photo aluminium) is attached to the black plastic
Hi Birty,yes its a different design on the T6... 3 main components to be separated once removed... Might get chance to put it back together today but what a pig its been! Updates to follow.
I gotta be honest.. I cant be 100% sure section 2 and 3 will split without removing the whole lot including section 1??? . There are two tiny screw attaching 2 to 1 and without the whole lot removed then I doubt if you can gain access and split them! I have just put it all back together now and not 100% happy with the joints. I cannot see any way of improving them . The spring clips that hold 2 to 3 are just not up to the job and think are designed for factory fitting..Sorry dont answer your question but hoping and praying nothing on that tailgate ever has to be touched again.. Mine already has camera fitted so very happy...Hi Birty,
Having recently removed the upper tailgate trim on our T6 Cali in order to fit a rear camera, I have been wondering how the lower section comes away. The problem that I still have is that I have been unable to satisfactorily refit the joint that exists each side between the lighter upper window surround trim and the darker trim below the rear window. I may have to remove it to correct the problem.
I have studied your photographs and there appears to be three plastic sections to this darker plastic trim. Leaving aside the picnic chair stowage bags, the lower T6 tailgate plastic trim seems to divide as follows:
1. The main section covering the area directly above the picnic chair stowage.
2. The section of plastic trim that fits over the rear windscreen wiper motor and forms the trim panel at the base of the rear window
3. The section that fits in front of the rear blind.
The second photo clearly shows the three sections.
My question is:
As you having recently removed and disassembled these components, in your opinion, would it be possible to remove the above mentioned trim pieces 2 and 3 without first removing the whole tailgate trim? I've tried to work this out from your snaps but am still in some doubt.
Many thanks,
Paul
P.S Excellent post BTW.
Thanks Birty,I
I gotta be honest.. I cant be 100% sure section 2 and 3 will split without removing the whole lot including section 1??? . There are two tiny screw attaching 2 to 1 and without the whole lot removed then I doubt if you can gain access and split them! I have just put it all back together now and not 100% happy with the joints. I cannot see any way of improving them . The spring clips that hold 2 to 3 are just not up to the job and think are designed for factory fitting..Sorry dont answer your question but hoping and praying nothing on that tailgate ever has to be touched again.. Mine already has camera fitted so very happy... View attachment 53978View attachment 53979
Spot on Borris.. Would love to know what the VW guys do to change a blind... But Im gonna say: Don't change the blind ever! Just sell the van!!!Thanks Birty,
Having studied your previous snaps, I rather suspected as much. I believe the screws you mention are located inside and behind the joint just above the black blanking plug in your latest photos. Two at each end. So it appears that there's no way you could remove them without taking the whole lower door card assembly off.
In that case I think I'll just leave it as it is. You chaps that have done this seem to be in total agreement that it's an awful job.
Thanks again.
Paul
Its a painful process getting to it unless someone knows a short cut... even then i dont think the blind cassette can be taken apart? Ask vw for quote first !!My rear tailgate blind won't retract any more, and to make matters worse it's a little slack so that when it's hooked onto the plastic hanging bracket, every time the tailgate is raised to get something out of the rear it falls down and whacks me on the head!!
Seems like a nightmare to remove the panels to get access to the blind mechanism to see what's wrong. It doesn't seem possible but any thoughts on how it might be fixed without panel removal?
Other than that I guess I'll just have to wear my cycling helmet every time I open the tailgate .
Thanks.
