GrannyJen
Very common fault, easy to replace yourself ( we sell them in the forum shop ) however you are probably best to try and fix yourself first using some cross weave tape.
I finally managed to remove the tambour door from the rear cupboard (see earlier post).
Do you still stock this door. The top and bottom runners and the two stops are fine.
I just need the door (for the rear cupboard, not the wardrobe).
How much including postage and VAT?
And how long from you getting an order should I expect to get it.
Thanks Barry
Guess that's a pointer as to which dealer NOT to use!The new one on display in our local dealer recently had sections of its door scattered in the boot...and a sagging roof on one side.
Don't know if you are still under warranty or not, but when I took Cali in for her MOT just before the 3 year part of the warranty expired, I mentioned that our door had split and they replaced it under warranty before I had to resort to the Gaffa tape. Might be worth a try.I've also encountered the dreaded tambour door fault.
I'll probably have a go fixing it myself. Is there anything holding the slats together other than the tape?
Sinclair Cardiff?The new one on display in our local dealer recently had sections of its door scattered in the boot...and a sagging roof on one side.
Sinclair Cardiff?
Well that was a lot more difficult and unpleasant than it had to be!It's in for its first service on Wednesday. I will ask about it then.
Not quite the same thing but the two clips that hold the doors closed on the hanging wardrobe side have broken on mine.
Last time it was in the dealers having something done I asked for a quote to fix them.
£3,344.00
Apparently the whole thing comes as one unit and has to be replaced ......
Did you order a Spare ?
I'm shocked that you don't know the 'rules' for fixin
In the summer our van interior got up to 38 degrees C stood on the sun at a folk festival. Our back-most door separated and I think the cross strip tape’s glue literally melted and lost the ability to stick when the door was opened. I think I saw a post by Aubergine-gine a while back referring to this too. I used some silver duct tape for a quick fix, but it’s worked well, no probs since and quick and easy to replace if it happens again. Reading through this thread looks like it’s worked for others too.If that's what they are called - one of mine has come apart. Is there any way to fix this, as it has to stay flexible? Or is it possible to replace it without taking the whole cupboard out?
