Help!...I've got a leak.
Found a pic on the web.I've added my scribbles to show how the dodgy drains are connected.
I suspect the bonding of the plastic drain to the glass could be the culprit as far as water getting in.
That’s extremely helpful. As I’m being a bit Of a numpty (sorry) can you also indicate which arrows show where the drain SHOULD go and where it is leaking.
It’s probably all there already... I just want to know for sure before (if you’re on with that) sharing with my dealer when the van goes in.
Thanks in advance.
Thought as much, so its basically down to the care of the original fitment as to whether the water which goes into the drain channel doesn't go back into the van.....
Thanks in advance.
The plastic assembly marked in red should direct water from the 2 drains straight outside (dotted yellow). (The one in the photo is damaged where the window was removed). Any water escaping from the assembly "above" the sealant will be running down the inside of the body panel.
  • Scan 2020-1-17 19.10.56.pdf
Ok so it's been into VW and it's the side window seal that's leaking or so theyt say...
So it's going to have to have a whole new side window fitted/bonded.
The VW Van Centre have spoken to VW Customer care and there is no goodwill offer from them to help cover the cost.
Which is a bit of a disgrace bearing in mind it's a 2016 vehicle.
Is it worth me calling VW Customer Care UK myself to push this as it's seems ridiculus to me for them to not pay anything towards it?
But at least it's going to be fixed, next week as it cant be done any sooner.
Lets just hope they connect up the drainage bits correctly.
I thought your taping of all the joints would have discounted the seals....
You mentioned you've only had it a few weeks, no warranty with the purchase?
Worth a call to VWCC to say you've only just bought it, with no indication of water issues prior to sale, but I wouldn't hold much hope but worth a try...
I’ve received a notification for the test for my window, at the end it says...
“As always please make the customer aware that the ingress has to be quite severe to get authorised by VW, and if new windows are authorised, they will likely leak to some extent, depending on the volume of rain and the angle it hits the window at.”
Which does make me hesitate going through the hassle of tests or new windows (requiring kitchen dismantling) if the new ones are not guarantees to not leak...
That's a very vague statement Alison that you've received, with "quite severe", "likely leak to some extent" and "volume and angle"! What's acceptable? No leaks are acceptable to me... I would not want any intrusive work done either which may make it worse with no guarantee.
Totally unacceptable response by the dealer. The California is for habitation use and no leak is the default. I would advise them of their responsibilty - but knowing the dealers up here don't hold your breath. This is sad and seems you have been treated badly. Keep fighting and don't give up.
It doesn’t read as though it was written by the dealer. Seems more like guidance they have received to pass on to the customer...
@Digger
I have a bit more time now, so my quote in total reads...
“Check for both side sliding windows leaking. Diagnostic session on fault above Price quoted £125+ VAT for initial diagnostics...
Water tests have to be carried out
Tests require a special tool fitted on to a water hose operating at a specific pressure, and video has to be taken of the water ingress, then send it to VW Germany. If VW technical feel the ingress is too much they will authorise replacement windows.
If they feel it is acceptable they will only authorise the window slides to be cleaned and lubricated with petroleum grease.
If a window(s) are authorised, some of the interior has to be removed to allow the glaziers in to change the windows. Depending on which side is leaking, this may involve the complete removal of the interior of the vehicle.
As always please make the customer aware that the ingress has to be quite severe to get authorised by VW, and if new windows are to be authorised, they will likely leak to some extent, depending on the volume of rain and the angle it hits the window at.”
I’ve not been quoted the £125 and there is no sum on the invoice. That maybe an internal charge between the Dealer and the Warranty department. But I will check it out.
The drainage is p
@Digger
My query back to VW would be, when they say “ingress has to be quite severe” does that relate to water getting into the vehicle through the window seal? Or getting through the window seal and flowing into the cupboards due to faulty drains? If they consider the latter to be acceptable, then they really are having a laugh!
The leak was from the window in the end, new side window fitted and now dry inside.
Thanks for all your help and suggestions, now looking forward to getting away and enjoying owning such a great van.
Welcome to the window club!
Just back from the Looe meet and looks like I’ve joined the window club! Cupboard under sink soaked, so now reading all the suggested solutions. Fingers crossed.
Welcome! If it’s the faulty drain, then it really is a replace window job. If still in warranty don’t be put off by the “threat” that the kitchen unit has to be removed..... it doesn’t.
Thank you! 2016 and out of warranty. Window was opened and closed quite a lot this weekend.
I syringed both drains and the water came out under the glass. Have cleaned all the channels and treated the rubber around the windows.
45mph winds and heavy rain, so am hoping that may have been the reason. Only time will tell now
Hi Calimagg
sorry to hear about your issue,
Can you share what you treated the rubber seal with ?
was it Gummi Pflege?
multiple treatments with Gummi Pflege will benefit the rubber and make it more pliable, help it seal and prevent sticking.
Hi Calimagg
Hi there
Yes it was Gummi. Did all the rubber about 3 moths ago, but forgot the sliding windows ☹️
I
francotravels
F
Defender90
Meoncoast
Meoncoast
Tunworththunderbolt
Hotel California
H
Lambeth Cali
5K
Lambeth Cali
Lambeth Cali
Painted Pilgrim
Painted Pilgrim
Painted Pilgrim
