I'd assume that the vehicle must be to the same specification as it was on first registration. In UK you'd have to change the number of seats/passengers that can be carried with the DVLA who would issue a new registration document. Probably an expensive process with your Authorities.Have to pass the technical inspection each 2 years. No idea why but they go apesh.t. if seats are missing
So will be some heavy lifting from time to time.
Thats not right in the UK . you just can't carry more passengers than there are seats listed on the V5 . Nothing at all to stop you taking seats out. especially on a vehicle that has sliding removable seats.I'd assume that the vehicle must be to the same specification as it was on first registrIn UK you'd have to change the number of seats/passengers that can be carried with the DVLA who would issue a new registration document. Probably an expensive process with your Authorities.
Never mentioned carrying more passengers than seats, obviously not legal or safe.Thats not right in the UK . you just can't carry more passengers than there are seats listed on the V5 . Nothing at all to stop you taking seats out. especially on a vehicle that has sliding removable seats.
Where are your you getting your info from?Never mentioned carrying more passengers than seats, obviously not legal or safe.
If seats removed they would have to be refitted for an MOT Test as the Tester would be required to test the number of seats listed on the V5 including the seatbelts. That is the same as in Belgium it would seem.
It may be wider & a bit longer, but it’s the same height and not much bigger inside, I also have double glazed windows and I forgot snow chains and the standard fit Eberspächer’sThe T5 and up are wider, highter, longer. Double glazed windows at the back. Picknick talbe in sliding door, seats in tailgate, heavy seats, heavy aluminium roof...
Mine weighs over 2500 kg "empty".
My head is hurting trying to figure this out.
2014 California 140bhp
Could I safely load 260kg + myself (80kg)?
Need to return 21 boxes of flooring but have no intention of damaging the Cali if not recommended / safe.
I wont be carrying anything else in the van.
260kg is well within the load capacity
I have had three 7 seat Discoverys, always took the 6/7th seats out, never had any MOT issues, never gave it a thought either.Our 7 seater was tested in December with the 2 seats removed. Passed MOT with no issues.
Perfectly safe but don’t put it all in the boot, better to load between the 2 axles.My head is hurting trying to figure this out.
