G
Guy Raymond
GRAY
Hi everyone. How much play should there be in manual sliding door? (2016 T5.1 Beach). The top roller isn't rolling, despite lubricating. It doesn't sound great. There is a bit of play when you push the top of the door, probably 20 mm ish, i'm not sure If this is normal.
The handle feels a bit loose. Can a novice remove the trim to access the mechanism behind?
One of the lower catches looks likes it's been damaged. See pics.
The rear arch has a light scratch (we saw this when we bought it) assumed by the table, which seems to be a common problem reviewing the threads. I was assured this was due to the table not being stowed properly, not the door dropping.
In the 5th pic of the door, between the sticker and the door connector is a void, is something missing?
The van is out of warranty and it seems that this needs specialist attention. Really hope it's not going to be a big bill!
Any wisdom? Pics attached. Thanks a lot!
