I've bought one of these from Maxxcamp along with the cover. It's worth having in case you need to brake hard or swerve.Hi everyone,
I have a portable toilet in my Cali, but it always slides on the floor when I drive. I saw these pictures in Facebook. Does anyone know where to sell this base that can fix it? And the cover.
Thank you very much.
Thank you!I've bought one of these from Maxxcamp along with the cover. It's worth having in case you need to brake hard or swerve.
Thank you!"Maxxcamp de" do the floor mount maybe possibe to find it elswhere, maybe even the club shop, as for a cover a packing cube from Dunelm turned upside down is a perfect fit and can be used as a seat our foot stool.
Was thinking about how to restrict movement of the loo when travelling, thanks for the idea.you want a cheaper and more flexible option?
Multi use and move it around easily when you reach your destination.
- Dunelm cover - I think about £15
- A ROK Strap - £18 for 2. you only need one.
With the fixed base option, you will struggle to get a carpet on.
Just looked at Rok straps, never heard of them before. What length did you go for and what bit did you attach it to and how, Kurienp?you want a cheaper and more flexible option?
Elly, these are the classic rock straps - see here - https://www.jsaccessories.co.uk/buy...HTrvBmVXKdPKa1TtEmtEW8cxL29HfvM8aAnBTEALw_wcBJust looked at Rok straps, never heard of them before. What length did you go for and what bit did you attach it to and how, Kurienp?
Thanks, K. That’s great.Elly, these are the classic rock straps - see here - https://www.jsaccessories.co.uk/buy...HTrvBmVXKdPKa1TtEmtEW8cxL29HfvM8aAnBTEALw_wcB
On the fitting itself, there is a cross bar below the seat and the straps have a loop eye at the ends which you can loop over
The pics are not very clear but hope you can get the idea.
Depends how heavy you are. If the box was used the right way up, I’d say yes. But you slide the box over the loo upside down and then put the lid on top (over the bottom, if you get what I mean). if you’re average weight and you don’t wriggle about, probably yes. I’ll try it out and let you know.Love the idea of the ottoman. Is it sturdy enough to use as a stool? Or is it just a covered just a cardboard box?
Yup, strong enough to support my 75 kilos + easily another 20-30. Remember, it has the PP as support below as well. You put it upside down on the PP, then you put the lid on.Love the idea of the ottoman. Is it sturdy enough to use as a stool? Or is it just a covered just a cardboard box?
The box is a bit taller than my Thetford 335 there’s a gap between your bum sitting on the ottoman and the top of my loo.Yup, strong enough to support my 75 kilos + easily another 20-30. Remember, it has the PP as support below as well. You put it upside down on the PP, then you put the lid on.
Just received my Dunelm cover, perfect!you want a cheaper and more flexible option?
I don’t know if you are aware but the Dunelm box comes as a flat pack. It takes seconds to return it to a flat pack which you can store elsewhere. And the flat pack is as thick as the lid.Does anyone know if the Dunelm cover over a 335 will fit in the boot when the rear parcel shelf is on its higher setting? Looking at website measurements and checking our van it seems I might get away with the main cover on the loo but the top cushion having to be stashed somewhere else - I don't think there's enough height to leave it in place (we also have a Calicap drawer, which takes a few mm out of the available height). Our local store can't order it in for some reason, so it would be good to confirm before I go to the hassle & extra expense of home delivery.
We travel with the ottoman folded down into its own lid (Only about 8cm high).Does anyone know if the Dunelm cover over a 335 will fit in the boot when the rear parcel shelf is on its higher setting? Looking at website measurements and checking our van it seems I might get away with the main cover on the loo but the top cushion having to be stashed somewhere else - I don't think there's enough height to leave it in place (we also have a Calicap drawer, which takes a few mm out of the available height). Our local store can't order it in for some reason, so it would be good to confirm before I go to the hassle & extra expense of home delivery.
