ianp
Disconnected the CP and no change. Now left disconnected overnight as WelshGas suggested while I go to work.Disconnected all the connectors to the Control panel or disconnected all 3 batteries?
As I feared all along it does point to the CP being at fault. What options are there now apart from an expensive trip to VW? Is it repairable?Disconnected all the connectors to the Control panel or disconnected all 3 batteries?
As I thought I mentioned earlier, the unit looks for the 12volts coming from the charger input to bring up that symbol.
Having removed the plug out of the charger you have removed the charger from causing the problem that leaves the Control panel.
Removing all the plugs from the control panel itself (remove the control panel) you remove all power sources from the CP in case it is still getting power from a source. once reconnected if the problem still persists then the CP has developed an internal fault.
I'd a mooch on the auction sites to see if there is a secondhand one, get a quote from VW just to see how much the damage is going to be first.As I feared all along it does point to the CP being at fault. What options are there now apart from an expensive trip to VW? Is it repairable?
If it still charges okay when plugged in, operates all the kit like roof, heater and fridge, then just ignore it?As I feared all along it does point to the CP being at fault. What options are there now apart from an expensive trip to VW? Is it repairable?
Thanks for your help over the last couple of days. Everything does still work and having seen some prices for a new one I could get used to the warning beeping while driving!If it still charges okay when plugged in, operates all the kit like roof, heater and fridge, then just ignore it?
Drill a hole in the sounder: that’ll silence it! You’ll lose the roof up warning but what the hell.Thanks for your help over the last couple of days. Everything does still work and having seen some prices for a new one I could get used to the warning beeping while driving!
Normally the repairs are for the Button or the Screen. You could ask. The company is Vertronics in the Netherlands.The Cali shop here did have some CP for sale, as is a fairly common problem. Also there is a place that does repairs. You'll need to do some searching here to find details.
Thanks WelshgasNormally the repairs are for the Button or the Screen. You could ask. The company is Vertronics in the Netherlands.
So leaving everything disconnected didn’t work?Thanks everyone. The shop lists reconditioned units but are showing out of stock, I’ve emailed Vertronics to ask if it’s repairable and foolishly got a quote from VW...£883.54. For the time being I’ll live with it while I look for a replacement.
No, reconnected the CP and no change.So leaving everything disconnected didn’t work?
Good plan but possibly not quite so drastic, could one leg of the bleeper be disconnected temporarily until the solution/fix is found.Drill a hole in the sounder: that’ll silence it! You’ll lose the roof up warning but what the hell.
Sorry, I did not mean to pick fault.Yes: I only said that as it may be a surface mount sounder on the pcb with contacts that are difficult to desolder.
