Alan Andrews
Like the original message here, we do use the internal cooking facilities to prepare hot meals.
We looked at possibility to install a Dometic CK2000 cooker extractor above the hob area.
It will require some special brackets, but will fit nicely.
It uses replaceable charcoal filter and 12V supply.
Quite widely used in the larger motorhomes.
Measurements: 28cm deep x 40cm long x 5.6cm thick. Which is very compact. I did aim to construct cardboard mock up, but this slipped.
When last checked was available on Amazon at £242.17
We aimed to check out at the Camping and Caravan show but this was cancelled due to Covid.
