K
Kingpin
My bulb failure light came on the dash and upon checking found the R/H Daylight running light not working. Thought it must be the bulb and when I eventually got it out ,it was fine. The problem was the contacts on the bulb holder had become blackened and slightly pitted. They weren't copper or brass as you would expect but steel with a very thin plating on them which I cleaned and then refitted, and it worked. A week later, same problem, so because getting the bulb holder in and out is quite tricky and I don't want to keep doing I ordered a new holder. Went to collect it and and it was different to the original, so queried it and was told this is a modified replacement, the difference being that it no longer had contacts but 2 wires taking the power directly to the bulb. Fitting does involve cutting the wires to the original bulb holder baseplate and splicing the new ones in. This is more easily done with the air filter box removed as there is not much space and cutting.the existing wires as far into the lamp as possible so they are longer and this makes it easier to work on them. Glad to say all working now. Cost of replacement part £25.00 and it seems only available at dealers.
Has anyone successfully fitted led bulbs to the DLR's these would reduce the current flow through the contacts,
but I believe you can have problems with the bulb failure warning lamp?
P.S. modified bulb holder on right.
but I believe you can have problems with the bulb failure warning lamp?P.S. modified bulb holder on right.
