Central locking fault
L
lekandjencali
Hi, I have an issue with my 2008 California’s central locking. Starting at the beginning of 2020 it began unlocking itself - drivers door only first, now both driver and passenger doors. This stopped over the summer but has just restarted. The local VW Van Centre charged me for diagnostics in Spring 2020 but couldn’t come to any conclusion and wanted around another £500 in labour to strip out the driver door card to have a poke around with no promise of success (I declined). I have watched various videos on YouTube which show corrosion on soldered joints on the wiring harness below the driver’s seat but when I stripped mine back the joints were crimped only and the copper was clean and bright. The other thing I have tried is bring the convenience control unit into the house to warm up/ eliminate any moisture. Whilst it remained locked for longer after I reinstalled it, it did unlock again overnight. Has anyone had similar issues and resolved them? I can’t find any posts that describe similar issues.
1. Are all doors actually locked, tailgate and sliding door with remote?
2. Can you lock with the key not the remote, and does it still unlock?
This might help.
Hi thanks for the reply. Door locking/ unlocking with the remote works as normal. Just tried the key though and all doors lock but then drivers door immediately unlocks itself whilst the rest remain locked. The door can be locked manually with key when the convenience unit is disconnected.
Sounds like a faulty microswitch in the lock mechanism.
does the door show open and closed on the MFD display?
If it is the lock microswitch as @Loz suggested, this might help if you want to just replace the microswitch,
This might help.
lock cylinder sets - Campmob. (Typ2/Transp./LT)(CAMP) [EUROPA 2008 year]​
part codetitlei
door lock
inner actuator
door handle, exterior
key
sender unit
lock cylinder sets
door lock
(1)3B1 837 015 AQdoor lock
(1)3B1 837 016 CCdoor lock
(1)3B2 837 015 AMdoor lock
(1)3B2 837 016 AAdoor lock
13B1 837 015 ATdoor lock
(1)3B1 837 016 CFdoor lock
37H0 837 349 Acover cap
(3)7H0 837 350 Acover cap
4N 90825801pop rivet
57H0 837 867 retaining bracket
(5)7H0 837 868 retaining bracket
6N 90929901pop rivet
9N 90800503oval head screw w/ internal serration (combi), self-lockin
10N 90798505countersunk multi-point socket head bolt
118Z0 837 033 Alock striker
inner actuator
(14)7H0 837 732 cable with clip
151J0 837 861 bellows
167H0 837 195 Alocking rod
(16)7H0 837 196 Alocking rod
173B0 837 187 Bknob for locking rod
3B0837187B 01Csatin black
18inner actuator
not for this model
19fillister hd. bolt
not for this model
207H5 837 225 Ainner actuator
7H5837225A 2ZZchrome
(20)7H5 837 226 Ainner actuator
7H5837226A 2ZZchrome
217E0 837 085 bowden cable
(23)7H0 837 885 Cmounting bar
(23)7H0 837 886 Cmounting bar
24N 90897604oval hexagon socket head bolt
251C0 837 211 Aunderlay
277H0 837 209 underlay
287H0 837 205 Ddoor handle, exterior
7H0837205D 3FZblack
7H0837205D GRUprimed
for painting in exterior colour
(30)1T0 837 233 Bhousing
311C0 837 879 Acap
1C0837879A 3FZsatin black
1C0837879A GRUprimed
321C0 837 879 cover for door lock
1C0837879 3FZsatin black
1C0837879 GRUprimed
34G 052778A2lock cylinder grease spray
(35)107 837 167 GKlock cylinder with housing
to retain the one key
system the key code
number and/or chassis
number must be quoted
when ordering
(35)107 837 168 GKlock cylinder with housing
system the key code
when ordering
(36)7H0 898 167 lock cylinders
(lock and key set)
cannot be used to restore
the one key locking
system !!
(36)7H0 898 168 lock cylinders
(lock and key set)
the one key locking
system !!
Loz, Welsh Gas, thanks for your responses. All doors individually indicate open on the MFD plus interior light comes on and times off after the door is closed so I don’t think that’s the issue. Photo attached - tailgate was open as well at the time. Do you think the lock mechanism may be faulty?
That was just the check for one of the microswitches that show door closed, there are 3 more internally in the lock mechanism. What I think is happening is the Safelock/unlock microswitch is stuck down.
Take a look at this for an idea of what's involved.
When you press the fob to lock the van, the door module (on the back of the window motor) tells the motor in the lock to go in one direction until the microswitch says its locked. If it doesn't get the signal from the microswitch it reverses the motor and unlocks again.
Non-US locks have the deadlock as well and this operates a second microswitch.
Take a look at this (us version without deadlock for a good explanation on how it operates.
And the part 3 video shows how the microswitches work.
Thanks again for your responses on this. The van went into my local dealer for a service and I asked them to take a look. They removed the drivers door card and checked connections etc, they couldn’t find any issues and it wouldn’t fault for them. It’s been stable since it appears it may been a connection issue that’s been resolved by their inspection (fingers crossed).
