Calimeup
Wookieevan
- Messages
- 48
- Vehicle
- T5 SE 180
According to the Parts Diagram, there is only 1 bolt.
Hi, does anybody know how to find the part numbers for this roof mechanism diagram? Trying to find a black clip which is no.5 in this diagram. Thanks a lot.According to the Parts Diagram, there is only 1 bolt.
5 | 7H7 067 071 | end piece |
By coincidence I have just received delivery of this very part from the club shop (7H7 067 071 - £1.50 each). Shayne said they'd never been asked for it before.Hi, does anybody know how to find the part numbers for this roof mechanism diagram? Trying to find a black clip which is no.5 in this diagram. Thanks a lot.
It's a special order, so best to email requesting part 7H7 067 071.I need that black clip too. Mines snapped off. Part number 5. Where do I find that in the shop?
CheersIt's a special order, so best to email requesting part 7H7 067 071.
What luck to have someone else just having sourced the same nondescript part, thank you. I shall order one ASAP. I’ll await your photo once you’ve replaced. Thanks again.
Both of these Torx screws fell out on my 2019 Ocean. How did you manage to refit the forward of the two as access is limited?As above had the roof up today and noticed that I have 1 bolt from each side at the back of rear roof scissors missing. Are these bolts prone to coming loose?View attachment 59762
Are you sure it is missing. According to the Parts Diagram there is only 1 per side.Both of these Torx screws fell out on my 2019 Ocean. How did you manage to refit the forward of the two as access is limited?
I don’t think there is a hole in the roof, only in the bracket.Thinking about this, if it’s tricky to get a bolt in there then just chop the head off a bolt and locate the stud in there then just add a washer and nut.
Can you take a photo?
Ahh, I see. That appears to be the front strut, or is it the rear scissors as in the Original thread post?View attachment 78122
Definitely two as recovered both and two on the other side. Appears to be T25 but I have damaged the single one I could get back as it was an emergency without proper tools. God knows how the foward one (right in photo) can be screwed!
It's the rear driver's side (right hand drive). They must have changed it as it does not resemble the diagram earlier in the thread.Ahh, I see. That appears to be the front strut, or is it the rear scissors as in the Original thread post?
If it is the front strut then it would appear the strut has to be disconnected at the bottom, fixed at the top and then reattached at the bottom. The roof would have to be propped up during this procedure.
Why does it need a roof hole?I don’t think there is a hole in the roof, only in the bracket.
Roof edge frame support if you wish to be exact, although it would seem to be different on the T6. 1, unlike on mine.Why does it need a roof hole?
