Looks like a great site. Would love to camp by Ullswater.
Shame about the caravan. Just above it to the right is The Eiger.
Is it the angle or are they packing them in on your site? Have a fantastic time.Shame about the caravan. Just above it to the right is The Eiger.
What a difference a blue sky makesBroke my Golden Rule and went Camping on the Bank Holiday...
It’s mobbed at this spot
Goss Moor
Ben Nevis Holiday park this morning, Bertie felt a minority.Broke my Golden Rule and went Camping on the Bank Holiday...
Goss Moor
What's with the aerial? Is good?Ben Nevis Holiday park this morning, Bertie felt a minority.
Works just about anywhere (What's with the aerial? Is good?
This attachment got droppedWorks just about anywhere (
LOG PERIODIC WIDEBAND FREEVIEW HD DIGITAL TV AERIAL CARAVAN MINI ariel arial NEW 5060160347563 | eBay
Easy installation with the use of F-Connectors. Multi use clamp allowing vertical and horizontal mounting. Protected against LTE/4G. Very discrete only 40cm long. Length: 400mm. Connection: F type.www.ebay.co.uk
Signal can be boosted with one of these.
Tristar 1 way Distribution amplifier | DIY at B&Q
This adjustable coax socket distribution amplifier from TriStar is used to improve picture and sound quality by amplifying weak UHF TV signals or FM/dab radio signals, helping you to get the best quality available. It's been specially designed for interior use.www.diy.com
NB this and the tv run off the inverter 240v from leisure battery or mains hook up, so usable
Takes a couple of minutes to mount, aerial lives in the camper chair holder, pole by B&Q https://www.diy.com/departments/tri...-6y2sWwuXI3yHnqs00xoCp5QQAvD_BwE&gclsrc=aw.ds
Awning rail mast clamp
Vision Plus Uni-Bracket & Plate Easily Attach Your Aerial Mast Caravan Motorhome | eBay
The adjustable Uni-Bracket is designed to clamp onto a number of profiles between 1 and 35mm deep such as step ladders, caravan grab handles, air-vents, awning channels or rain gutters. Alternatively there is the self adhesive Uni-Plate which is specially designed to accommodate the Uni-Bracket.www.ebay.co.uk
And a dash cam suction cup for base of pole to give 2 point fixing.
plus various connectors and cable to connect outside van and then give a tv connection inside.
Cable enters van via left hand light cluster cable trunk, behind kitchen unit and out at floor level by B pillar.
Excellent, thank you very much. I may buy all the bits and pieces.
Just an extra use F type connectors for everything except the final one in the van which needs to be F type to coaxial plug.Excellent, thank you very much. I may buy all the bits and pieces.
Sorry to everyone who thinks this post went off piste but see #190 for reason for replyJust an extra use F type connectors for everything except the final one in the van which needs to be F type to coaxial plug.
Reason, the constant making of the connections is useless for coaxial connectors whereas the f types have been in use for 2.5 years with no rebuild.
Splicing Kit fr Extending / Repairing Satellite or Cable TV CT100 RG6 Coax Cable | eBay UK
Coax Cable.www.ebay.co.uk
Where and when was that please ?![]()
Just arrived in Italy
It is where my son and I spend many weekends adjacent to the lineNot the best site I've been to but possibly my most unique picture - Woodyhyde Campsite near Corfe Castle, Dorset.
