clarinetbcn
T5.1 Beach 140
So true, makes you remember to appreciate what forums are really for.Dealers have no chance to compete with the quality of hot air from here
Thanks to the Forum's excellent search function, I've learned that you're not supposed to actually use it, just talk about using it.I tried some of the hot air from the forum but it only resulted in a blow out.![]()
It’s on back order ATM, something to do with a B word, C word and a ship in a canal!An argument can me made for OEM, if you can find it. See post #58.
Isn't that just recycled winter water?Anyone tried Spring Water?
More bounce I believe.Isn't that just recycled winter water?
Don’t be sillyAnyone tried Spring Water?
The Farmers do it.
Tractor Tyre Ballasting
Tyre ballasting is where the tubeless tractor tyre or inner tube is filled with water in order to provide extra weight to stabilise a tractor. It can also be used to lower the centre of gravity ofwww.bigtyres.co.uk
And what about the chickens?An uncle of mine used to be a farm manager. In the winter the water in the tractors’ tyres would freeze and the wheels would turn with a big clump every complete rotation where the bottom had frozen flat like a bit sliced off a doughnut.
The chances of freezing could be reduced with anti-freeze added to the water.
So there’s the solution for winter: replace the summer air with antifreeze.
Timely reminder for all those who have not switched to summer air. This expansion malarkey specifically impacts winter air.
I keep seeing this thread pop up but when ever I ask at the tyre store they don't know what I am talking about. Kwik Fit used helium on the last time I have tyres replaced which incurred an extra charge and I have not seen any difference
And load capacity? Or will it?Surely your MPG has improved...?
Safety wise no improvement but prevents the additional weight being detected by the weighbridge!And load capacity? Or will it?
Only benefit is in 6 foot deep water, test report will be more interesting than 'winter air'.I keep seeing this thread pop up but when ever I ask at the tyre store they don't know what I am talking about. Kwik Fit used helium on the last time I have tyres replaced which incurred an extra charge and I have not seen any difference
The safety must have gone worse. The road holding (??) will be a lot less.Safety wise no improvement but prevents the additional weight being detected by the weighbridge!
Good point. Helium needs it own thread as it necessitates a a change in tyres. Let's keep this thread pure and focus on winter and summer air. New autumn and fall air also now available - but that's all a con - as it is not too different from winter or Summer air and they charge a premium.The safety must have gone worse. The road holding (??) will be a lot less.
Better have some sticky tyres for some friction.
I think I said it last year when the subject came up, I changed the old van to 4 seasons air just to save the hassle.Good point. Helium needs it own thread as it necessitates a a change in tyres. Let's keep this thread pure and focus on winter and summer air. New autumn and fall air also now available - but that's all a con - as it is not too different from winter or Summer air and they charge a premium.
Suggest you put a call in to Sinclair’s in Cardiff - they seem to know their stuff. I was in there on the weekend to enquire about a tyre flush and summer air refill. He said if I went for Welsh gas he’d throw in a good rimming in for free. Any reviews on Welsh gas? Is it worth the Premium? Will I still get the same promised mpg improvement when I drive in England?I now need rimming again , am I best replacing my wheels with steel ones ?
