So far cross fingers there’s nothing on the front panel. But I have decided that if it does appear I’m not getting VW to fix it because of the latest method used. I would probably rub it down use a special primer and paint it myself.
MY = Model Year.Thank you for this helpful reply.
If I quote the VIN number to VW, would they be able to tell me if the vehicle was constructed with the new alloy above the windscreen? It's registered in January 2015 so do you think it's likely to have been constructed in 2014?
With regards to the problem with the elevating roof, are we talking about flaking paint or deterioration in the aluminium frame that could with time compomise the integrity of the roof? The tape solution sounds a very primitive fix for such an expensive vehicle but if it works, so be it. Has anyone had any recent experience with waiting times?
Excuse my ignorance and daft question but what does 'MY' mean?
Thank you again for sharing your experience and knowledge.
Thank you for clarifying the process.MY = Model Year.
Although probably constructed in 2014, MY 2015 started production on 1st July 2014 and runs to 30 th June 2015.
The problem is not “corrosion “ as in “ rust “. It is Galvanic Corrosion due to the presence of 2 dissimilar metals in close contact in an electrolyte, in this case in pure rainwater. This is basically a chemical reaction and is basically cosmetic rather than structural.
On the elevating roof, made of aluminium, it is difficult to get good paint depth on the edge of the aluminium panel. The edge then has a rubber seal fitted with a steel insert. So steel + aluminium + impure water = galvanic corrosion.
Thank you for sharing the photo of your vehicle. I hope you managed to have it sorted.This is what it looked like on mine at about 3 years old. Not the same all around but some areas worse than others.
Yes had it done at Sinclairs van centre. Swansea,Thank you for sharing the photo of your vehicle. I hope you managed to have it sorted.
VW should have know right from the beginning that this was not the ideal thing to fit on an Aluminium roof. But they continued for years. VW philosophy is always fix it then solve it.. Could have saved millions by just using a different roof seal.Thank you for clarifying the process.
I'd just Googled 'galvanic corrosion' and even with my abject GCSE Chemistry grade, managed to get my head around how this happens and how the choice of materials and operating environment influences whether it occurs or not
unfortunately they have not solved itVW should have know right from the beginning that this was not the ideal thing to fit on an Aluminium roof. But they continued for years. VW philosophy is always fix it then solve it.. Could have saved millions by just using a different roof seal.
I don't think vw have any solution to the problem. except after the first respray we need all to to pay for resprays every 5 yearsunfortunately they have not solved it
Ha ha, its just like owning a vintage van - have a friend with a 1972 bay window and he has it resprayed about every 6-8 years due to corrosion continually coming back!!unfortunately they have not solved it
That's good news . Breeze Southampton are always very helpful but I am afraid they had no joy with VW in my caseThe previous owner of my 2010 T5.1 SE had the front cowl replacement done in 2017 with a three year warranty. I purchased it in 2019 then in 2020 I noticed water ingress into the cab roof lining and saw the sealant was cracked around the cowl so I contacted the VW dealer who had arranged the original repair, Breeze Southampton via VW Heritage Bristol, and Breeze contacted VW Customer Services who approved the cowl removal and replacement which was done via Claridges Southall who collected and returned my Cali via the AA. Claridges did a great job and touched up a few other minor rust spot with VW approval and all free of charge! They whole process took about a month with VW approval causing the most delay but I'm very happy with the result. Apparently VW has specified an improved cowl sealant since 2019 so hopefully no more issues.
I wonder how much extra it would cost to have a proper job done, ie. new alloy front cowl, instead of a plastic cover ?Just take a lot of pictures inside and outside of your Cali before it's collected and when it's returned. I had my 2010 T5.1 SE main roof done September 2020 by VW via Lookers North Shields and they did an excellent job with good communication throughout the process. I had about 7 small bubble areas around the roof edges and a couple under the front of the elevating roof so they got VW approval to take the roof off and respray all of it as it was quicker. They also fitted the tape around the roof edges and a new rubber seal. Perfect now so let's hope it lasts another 10 years!
The front cowl corrosion is more of an issue as VW cut away part of the aluminium front cowl and stick a plastic cap over it with the potential for future issues of the seal cracking and water ingress, if mine hadn't already been done before I purchased it I would have taken it to an aluminium specialist for repair.
Think I'd get a quote off a classic car repairer if I ever need to.I wonder how much extra it would cost to have a proper job done, ie. new alloy front cowl, instead of a plastic cover ?
Mine went to Newbury, I thought they did an excellent job and like you I was in fear and trepidation for two years waiting for it to be done.My 2013 T5.1 SE is due to go go to Marshall’s in Newbury for the main roof galvanic corrosion warranty repair.
I would be interested to know if anyone has had the repair carried out at Marshall’s, any feedback would be much appreciated.
Still undecided as to whether to trust VW with the repair after reading some of the stories on here or to foot the bill and use a recommended independent.
Does anybody have any recommendations of a suitable independent?
Thanks in advance.
Reassuring to hear some success stories! We, too, are at the 'fear and trepidation' stage so this is some nice balance.
I should say that this was a 2015 T5.1, I don't want to worry anyone who looks at my profile and sees that I have a T6.1. The repair was last June and I changed my van in September.Mine went to Newbury, I thought they did an excellent job and like you I was in fear and trepidation for two years waiting for it to be done.
I think I saw somewhere on this thread that an owner saw an invoice for about £5000 or so for the repair when they were replacing the front roof section.I wonder how much extra it would cost to have a proper job done, ie. new alloy front cowl, instead of a plastic cover ?
I know it's a little bit late in the day to come up with this. What l meant was, If it cost VW, say £2,000 to put a plastic cap on. Could you say to them I don't want that, I'm prepared to pay the extra £------------ and have a proper job done, and have a replacement new front alloy casting.I think I saw somewhere on this thread that an owner saw an invoice for about £5000 or so for the repair when they were replacing the front roof section.
Thank you for your response, it is good to know that there is some positive feedback.Just take a lot of pictures inside and outside of your Cali before it's collected and when it's returned. I had my 2010 T5.1 SE main roof done September 2020 by VW via Lookers North Shields and they did an excellent job with good communication throughout the process. I had about 7 small bubble areas around the roof edges and a couple under the front of the elevating roof so they got VW approval to take the roof off and respray all of it as it was quicker. They also fitted the tape around the roof edges and a new rubber seal. Perfect now so let's hope it lasts another 10 years!
Thank you that is very reassuring.Mine went to Newbury, I thought they did an excellent job and like you I was in fear and trepidation for two years waiting for it to be done.
I'm sure they would do it, but I doubt if they would discount it by the £2000.I know it's a little bit late in the day to come up with this. What l meant was, If it cost VW, say £2,000 to put a plastic cap on. Could you say to them I don't want that, I'm prepared to pay the extra £------------ and have a proper job done, and have a replacement new front alloy casting.
