D
Demelza & Ross
I cannot find the button to turn off the interior motion alarm if I want to leave the dogs in GC 680. Looked at VW GC Chris YouTube but nothing like it in our van. Thanks in advance.
I’ve looked but nothing there. CheersOn the T6 it’s on the BPillar just behind the drivers seat
i know. thats why i said check in the menu on the grand ? . i was pointing out that i knew it had moved on the 6.1. was just a tip. as i really don't know where it is on the grand but thought it was worth a check as no one else repliedThe OP has a Grand California not a T6 or T6.1.
As everyone says it’s on the B piller driver side beside the seat.I cannot find the button to turn off the interior motion alarm if I want to leave the dogs in GC 680. Looked at VW GC Chris YouTube but nothing like it in our van. Thanks in advance.
I’m off to have a better inspection of the B pillar. Thanks everyoneAs everyone says it’s on the B piller driver side beside the seat.
It is at the side of the bed, fixed on to the side of the kitchenI cannot find the button to turn off the interior motion alarm if I want to leave the dogs in GC 680. Looked at VW GC Chris YouTube but nothing like it in our van. Thanks in advance.
No that’s the door lock. Which also isolates the interior sensors the one on the B pillar isolates motion internally and externally when you lock the van from outsideIt is at the side of the bed, fixed on to the side of the kitchen
I need to check them lol. I don't want to set the alarm off when parking up asleepNo that’s the door lock. Which also isolates the interior sensors the one on the B pillar isolates motion internally and externally when you lock the van from outside
The handbook tells you nothing about what to do especially when you are sleeping or you have dogs inside when you leave. So if I settle for the night I switch the locking button at the side of the bed? I can move around with setting the alarm off?No that’s the door lock. Which also isolates the interior sensors the one on the B pillar isolates motion internally and externally when you lock the van from outside
Nothing on B pillar. Only door lock when insideNo that’s the door lock. Which also isolates the interior sensors the one on the B pillar isolates motion internally and externally when you lock the van from outside
No. Just to lock when inside.It is at the side of the bed, fixed on to the side of the kitchen
Hand book is crap. And yes press the button beside bed it locks the doors and isolates motion detector. Press same button in the morning to release lock.The handbook tells you nothing about what to do especially when you are sleeping or you have dogs inside when you leave. So if I settle for the night I switch the locking button at the side of the bed? I can move around with setting the alarm off?
I have found it - Yay . I had to sit in seat to see it !!
Thank you everyone for your help and thank you Breeze1 !!I have found it - Yay . I had to sit in seat to see it !!
Well doneI have found it - Yay . I had to sit in seat to see it !!
Thanks very much AlisonF - good to know. We’ve only been out in it once back in October@Demelza & Ross if it’s the same as the T6 then it needs to be pressed when driver’s door is open (many used to make the mistake of doing it from sliding door which does not work). The light should change from red to orange. It will stay in this mode until you change it back (so doesn’t need to be re-set every time you leave the dogs in the van).
It should definitely light when you activate it.Has anyone been successful using this button? I’m in a 680 and following the handbook can’t get it to work. I took the key out of the ignition, opened the drivers door and pressed the button, which wasn’t illuminated before or after pressing. Wife was inside and gently moved around (mimicking the cat jumping from the bed) which triggered the alarm.
Last thing I want to do on a campsite is leave a van uncertain if the alarm is going to keep going off!
Thanks. Found out that plugging in hookup disables the function, I now have it working but it’s a shame it won’t work with hookup as fan was plugged into mains, will have to find 12v fan to keep it cool for the cat.It should definitely light when you activate it.
