a892374923874
I'm contemplating making toilet cassette emptying a little easier at home.
I have a circular plastic manhole cover against a wall outside, so I could drill a 110mm hole in it and install a 45deg bend, a drop pipe and a screw cap. If I use a 110mm coupler above the manhole then that will stop the pipe dropping through. I have a fresh water pipe near it to provide a rinse.
However I don't really want any splashes remaining in the area.
Alternatively, we're building a wet room inside, which will have a shower and a toilet, so I could tee off the toilet waste and provide a similar screw cap arrangement in the shower area so any splashes could be rinsed off with the shower. I could provide a separate rinse tap also.
Any other creative plumbing arrangements spring to mind?
