Rattle from speedo console
Defender90
Defender90
North Yorkshire
T6.1 Ocean 199 4Motion
A Rattle has started from my speedo console if you lightly touch the screen it stops, not sure if it’s the console that’s loose or the plastic surround that touches the screen.Has anybody had a similar issue?it only rattles on rough roads.
Hi can any one help with this issue i have noticed if you tap the middle of the screen it sounds loose does anyone else's do the same?
Hi,
like all rattles they may not be to easy to locate especially from the driving seat whilst moving.
it could be from a surround panel touching the screen/speedo area.
Maybe as I have done in the past, a piece of masking tape to anchor a suspect panel etc to help eliminate or locate the cause.
good luck.
