Bumble The Van
Mine is just about to arrive and i suddenly realised i dont know if an ocean has any body panel insulation as standard ? Would be a help if anyone knew please?
Cheers Calimilli i wonder if you can have this done as an aftermarket service?No it doesn't but it does have double glazing instead (except for kitchen window and in the "cockpit").
All the tanks are internal though.
Everything can be done but the cost and the complexity not worth it. And , as true for every van based camper, because of its metal structure , it will always have cold bridges.Cheers Calimilli i wonder if you can have this done as an aftermarket service?
no real concern but i just didnt know if someone could improve on the standard for a few hundred quid and it be better than the original, but no real concern , and your right if the diesel heater solves that then great , but have the solved the ticking noise yet , in my t5 it was truly annoying , but not sure if technology has changed and its quieterEverything can be done but the cost and the complexity not worth it. And , as true for every van based camper, because of its metal structure , it will always have cold bridges.
What exactly is your concern?
The VW solution is in the oversized diesel heather. it's 3kw for a tiny van. It will keep you warm even if the van is poorly insulated. You will feel some cold drafts, but overall the system works.
Although I agree with VW in not insulating the limited panel coverage, your statement is untrue.If you insulate, condensation will form on the internal surface of the cold metal skin, leading eventually to corrosion, and soggy insulation. VW have this right.
Modern insulation can be hydrophobic, but by definition the exterior surface is still cold, and condensation occurs. Interstitially in ‘wools’. Rigid insulations squeak. Doors have drain holes, but not usually internal panels. And drain holes, and Fiats, well…Although I agree with VW in not insulating the limited panel coverage, your statement is untrue.
Modern insulation won't get damp as it's mainly plastic based thus doesn't absorb moisture. Any excess moisture on inner panels is designed to drain to the bottom and out if the designated drain holes. If it didn't ALL vans would rot from the inside out....and they don't.
