Insulation
VWDrooper
VWDrooper
Norfolk
T6 Ocean 204 4Motion
Does any body know if the Grand Clai comes with any insulation in the walls, floor etc ?
California4x4
California4x4
Scotland
T6 Ocean 150 4Motion
I’m afraid I don’t know but as the T5/T6 California has none, apart from double glazed windows, I would be surprised if there is any. Many of the Grand California’s competitors will have insulation. It will be interesting to find out. The small volume of the California gets away without specific insulation. The almost complete lining with plastic helps a bit I think and the heater, designed for larger spaces copes fine even in sub zero conditions. I’ll be following this thread with interest.
Stewart1150
Stewart1150
Dorset
Cali now sold
For the price, I’d be expecting gold standard insulation - as said competitors have a range of branded insulation. Watching with interest ............
Jay20cali
Jay20cali
Uk
It should have our westfalia columbus has it in every orifice.is the GC winterised?
Adeybruce
UK, USA and Turkey
Grand California 680
I can partly answer this question.
Yea there is insulation. The sidewalls have around 8cm of plastic loft-type insulation.This is covered with a kind stretchy foam/rubber insulation forming a additional layer and presumably moisture barrier. The blown air heating system in addition to the main vents, has 2 smaller hoses that run into the sidewalls where on one side some water pipes are located, and on the other is next to the 100 litre water tank. The underslung grey water tank is not insulated (and to my knowledge not heated).
A couple of pics attached. First one shows the electrical cupboard where the 2 smaller heating hoses split from the main pipe. The other is the water cupboard (in the 680 it is accessed from above); here you can see some of the loft style insulation.
Adeybruce
UK, USA and Turkey
I presume the red, blue and green colours relate to different types/qualities of insulation?
Adeybruce
UK, USA and Turkey
Well it’s minus 4 outside, but little wind.
despite having heating on low , it’s pretty toasty inside.
So far very impressed with 2 things:
- the insulation is doing a good job
- the heating is really progressive. By that I mean it can maintain a temp unlike my T5 and T25 with their heating systems (Webasco and Propex) which blast out hot air having you kick off the duvet, only for it to off-cycle and you freeze.
As an aside, the 4 Motion gave me a lot of confidence getting up here.
Breeze1
Breeze1
Dorset
Grand California 600
Love it.
Incidentally did you have the WiFi router option fitted and if so does it work well?
Breeze1
Breeze1
Dorset
Thanks.
No WiFi router, seemed pointless when our phones have hotspots.
Ok thanks but for your info the WiFi router option hotspot is reportedly x6 times stronger than the phone
Adeybruce
UK, USA and Turkey
Thanks for the info. That’s a more interesting proposition then. By 6 x stronger is that for the reception/transmission of the 4G signal or the WiFi signal? When I travelled around the States I was always interested in the van mounted powered mobile phone antennas, which provided reception where a standard phone had no hope. There were lots of mixed reports about various products and I couldn’t work out which the best one was, and they were expensive, so I never went for it.
Breeze1
Breeze1
Dorset
Morning,
At the time of ordering the GC I took a flyer and ordered the optional WiFi and router without info.
Whilst at the stealers the other day one of the sales team offered some literature on the WiFi. See link.
Supose it can be retro fitted.
R
rome
Eskilstuna
Looking to buy
Picture from a sales rep training in Sweden.View attachment 54056
The sales rep reply's something like this: " They did not explain the colors. It displays all insulated surfaces in wall and ceiling.
It may be that there are different materials in the walls and doors. Can also be so just to see the difference between what is wall and door. But all colored parts are insulation.
You also have about 4cm insulation in the floor, so the whole "cabin" is insulated to withstand winter use."
Adeybruce
UK, USA and Turkey
Thanks the info
