Got my Copper/Bronze set from Transporter HQ @4x4 joker . Set of 6 Thruxton Grille Strips. They are supplied unfinished but they will spray to any colour.Anyone know if the chrome ones unclip and it’s black underneath?
Where did you get them @GrumpyGranddad
does your solar charge leisure and starter or just the leisure Batteries?Question? I have a Ocean 6.1 this years reg and a solar panel fitted and as I live in a terraced house I park on a street away from my house. Reading the posts about you should hook up to the mains to keep the batteries in peak condition has got me concerned as I have no way of doing this and my pride and joy is sitting idle this Winter...any suggestions?
If your solar system isn’t set up to charge your starter battery @Cali uhuru you could perhaps use a cheap ‘battery maintainer’ plugged into a 12v socket and laid across your dashboard?does your solar charge leisure and starter or just the leisure Batteries?
if the latter, you could upgrade the system to do all.
otherwise just take it for a drive every 3 weeks.
Thanks for the info Loz I am told the panel charges the leisure battery and GrumpyGranddad came up with a solution that will do the trickdoes your solar charge leisure and starter or just the leisure Batteries?
Nice - was it colour matched already or did you have to get that done?Long story but due to an error by the supplier of the Thruxton Grill Strips I bought recently, I was offered the Thruxton splitter at a massive discount so treated the van to an early Christmas present. Now just waiting to fit it. The grey van pictured has the same one fitted along with grill strips. I like the look.
Out of interest @GrahamB do you find audio quality better with a wired connection rather than wireless? I use Carplay wirelessly and it sounds fine (mind you my 70 year old ears might be a little less discerning )Got a neat MagSafe iPhone holder from the online emporium.... https://www.amazon.co.uk/dp/B08XYQDGHP/?tag=eliteelect-21
It's decent quality, and ideal for MagSafe charging iPhones and the magnet seems powerful enough. It will also work with other phones using a stick on magnetic ring which is supplied. I like it because I now have a safe place to hold the phone whilst wire connected via the usb-c slots to CarPlay and get best quality sound out of the audio set up. Previously I couldn't find a sensible place to keep the phone. Stuck to the dash in a convenient spot with 3M tape (also supplied).
View attachment 87298View attachment 87300View attachment 87301
The supplier sprayed it @GrahamBNice - was it colour matched already or did you have to get that done?
Result! Look forward to seeing it fitted.The supplier sprayed it @GrahamB
That was their mistake, they sprayed the splitter in error instead of the grill strips i’d ordered and as it’s one of the more unusual colours, rather than it sitting on their shelves for evermore, they did me a very good deal
Yes it is definitely better wired. CarPlay over Bluetooth is good enough, but if you compare them back to back you notice the degredation in sound quality with wireless. There's more information (e.g. instrument separation) and openness to the soundstage with wired connection. Better still if you use lossless downloaded files rather than streaming.Out of interest @GrahamB do you find audio quality better with a wired connection rather than wireless? I use Carplay wirelessly and it sounds fine (mind you my 70 year old ears might be a little less discerning )
They’re just been following you on here and knew you like buying stuff for your van so got it ready reallyThe supplier sprayed it @GrahamB
Proper barn doors!
Haha - have you got some sheep in the back?
