66tim99
Only works with aftermarket non canbus head units thoughThis is what you need, apparently - although I have not fitted myself
Drive/Camping Switch Wiring Kit – Wildebus
wildebus.com
wildebus.com
wildebus.com
Looks like that just connects the power to a live feed. Tha Canbus will still turn it off after twenty minutes.
Looks like it should do the job then. What is the handbrake mute for? I don't think you will find a leisure battery feed in the front anywhere. Could be wrong. I just ran a cable from the underseat battery under the doorstep and up behind the dash.It’s an aftermarket unit rather than the VW one.
The actual harness I’ll be fitting is this one
Quadlock to iso with advanced can bus and leisure battery integration.
PLEASE CALL SHOP TO ORDER THIS PRODUCT Tel 01422www.skiptoncarradio.com
What I’m trying to figure out if I need to run the power all the way to the seat / leisure battery or if I can take a feed near the stereo (fuse box)
Interesting. I'm actually more interested in keeping the van wifi on permanently (rather than the stereo) - does anyone know if the inbuilt wifi is part of the same system and hence would maintain power when wired this way?This is what you need, apparently - although I have not fitted myself
wildebus.com
Yes. You need to enable video in motion with VCDSNo it's a software hack
Sounds like a sensible move, to avoid having to keep pressing the on button. If your on hookup, no need for the 30 min switch off so I’m following this potato’s l fix with interest.I had to take our Ocean to the garage and took the opportunity to switch the wiring from main battery to the leisure one, in particular the one under the driver's seat. In our case, it now stops after 30 mins, not 20 as it did before the change. Has anybody experienced this?
I don't know whether to ask for this limit to be removed, or just live with it. After all, our objectives were two. First, feed the radio from leisure battery, and second, avoid having to carry more devices, when the van has a fantastic sound system.
