D
dominichayhoe
This forum is such a mine of info, I've definitely learnt a lot here. I've also noticed quite a few questions or mistakes about the way the van operates, mostly to do with the way certain things operate, so I thought it would be great to have a thread where we can all chip in our discoveries!
For me a few things spring to mind.
1. The step automatically goes into camping mode as soon as you plug the electrics in and you can't turn it off from the control panel - makes sense but I don't remember reading about it anywhere and I thought the control panel had frozen on me the first time I noticed this.
2. The battery charger's cable is really easy to kick out from under the passenger seat without realising it!
3. If the control panel does freeze, a quick red button off wait 20 seconds and back on fixes it.
4. I blew a fuse (my fault) but just replacing the fuse didn't fix the issue. I had to cycle the big red nob off for 15 minutes and then switch it back on to give the main control unit time to properly power down.
Anything else anyone can add that isn't immediately obvious?
