The Forum search function is your friend:The headlights on my T6 are really pretty rubbish , even on full beam. What do I need to do to change up the bulbs for some that are brighter? Is it something I can do easily or is it a garage job ? Thanks
I'm assuming that you have twin H7 headlights. If H4 single type I'm not sure about the DRL bulbs.Thanks , Thats a great help
I thought the Beach came with the H4 headlights, H7 and LED being the upgrade options.Hi Nadir
Did you change out the bulbs and did they help, I've had a couple of poor experiences with the T6 twin lights, I assume H7's.
One of the easiest upgrades is changing your H4 headlights to H7 headlights, either using genuine VW headlights or 3 rd party equivalents.I have indeed H4 and today have popped down to Halfords and purchased 55w brighter than bright lights apparently.
Having now changed my T6 BEACH headlights units from H4 type to H7 I wish to sell the old ones. Are they compatible with the T5 and T6 Transporter Vans?One of the easiest upgrades is changing your H4 headlights to H7 headlights, either using genuine VW headlights or 3 rd party equivalents.
H4 To H7 Upgrade
Replaced my standard H4 headlights on my 17 plate kombi highline with genuine H7 headlights from a 17 plate Caravelle. It's literally just plug and play, no warning lights, no VCDS, just swap and go. Does require removing the front bumper but really not as bad as it sounds. IMO the H7's are...www.t6forum.com
Many thanks for such a quick response BJG.No. Headlights relate to a specific model.
Are you sure. I agree T5 for T5 and T6 for T6 but I think the OP's H4 headlights would be compatible with the relevant T5 or T6 commercial vans, but I doubt if there would be a large market for themNo. Headlights relate to a specific model.
T6 headlights across the range (Cali is the same as a van or any other T6 variant regarding headlights) but not any other Tx model.Are you sure. I agree T5 for T5 and T6 for T6 but I think the OP's H4 headlights would be compatible with the relevant T5 or T6 commercial vans, but I doubt if there would be a large market for them
Just sold my old T5.1 H4's for £90 on Ebay.T6 headlights across the range (Cali is the same as a van or any other T6 variant regarding headlights) but not any other Tx model.
H4 lights are the main ones converted giving a pool of second hand ones with little or no value.
Worth an EBAY listing for either a low start figure or reasonable amount with offers.
I don't believe Carista will do this. VCDS will definitely. Not sure about OBDeleven.I need to do some coding after changing H4 to H7 headlight units on my Beach so dipped lights also work on main beam. Would a Carista do this or is there a better system?
Many thanks WG will check out the T6 forum.I don't believe Carista will do this. VCDS will definitely. Not sure about OBDeleven.
Check out the T6 Forum . They have a list of VCDS users who are happy to do coding changers for members, or possibly track down a VW Independent.
