I would say spokes up, so that water etc cannot pool.Refitting spare wheel. Strange question.
It’s a 17 inch steel, which way up does it go, spokes facing up or down?
This.I had my spare spokes down and positioned with the valve towards the rear so I could check the pressure without removing the wheel.
Alan
but remember ... either way ... with all good intentions of checking air and all, unless you get a puncture, it will be like the forgotten child ... I have not checked the pressure in the spare for over a year now. But I know that (hope thatDamn, both ways make perfect sense. Am I going to have to swap it now lol
) all is well down under ...Get an alloy spare that matches exisiting wheels, then no need to worry about rust.This.
Two advantages:
1. Check pressure without removing the wheel.
2. The part of the steel wheel that rusts first is the narrow well area on the top of the wheel (marked in RED in the image below). There is a weld here. Mounting it with this area facing downwards helps to reduce water pooling and rust build-up. At the rear side of the green circled area (image below), a bit of water pooling will not have a weld to rust.
Another advantage of spokes down, is that you can then wrap up a proper set of tools and jump leads etc. in a rubble sack and put it in the" bowl" that the wheel makes.This.
Two advantages:
Yup, that's the better / recommended way!If it helps I’ve just been out to check mine: this is how it came from the factory
Edit : looks surprisingly clean under there after four and a half years !
and you haven't paid attention to @WelshGas either, as he once explained this very fact, noughty!Manual is not much help.
Although I never realised there is a hole in the bracket to put the wheel wrench handle into which helps you lift the wheel back up.
Fig 233 below
Bollocks. I’ll have to swap it nowIf it helps I’ve just been out to check mine: this is how it came from the factory
... unlikely ... unless you've been to Legoland in between then and now.About time to repeat the process for this year I guess, assuming someone hasn't stolen it in the meantime
