Perfectos
The figure of 8 strips are 6mm
when using the transition Kit 4 x6mm the 4mm side of the Kador strip the fits the Wind out awning (WOA) leading edge,
the 4mm side goes direct to the WOA awning, the other 6mm side attaches to the Figure of 8 strips.
if using the clipping to top of awning method,
you don’t need to use the 4 x 6mm transition strip at all.
you simply but your drive away awning (DAA) into the Figure of 8,strips attached to the top of the WAO.
kador attached to the DAA will be 6mm as standard and slides into the figure of 8 (attached to the WAO)
have a look at the photos on post #8 DAA (6mm Kador sewn to the DAA) attached direct to the figure of 8 strips
hope that helps & clarifies.
edit: Clear Helicopter tape can be used to Wrap the front face of the WOA, to prevent scratches post #8 if you look closely at the front face of the WOA yiu will see it is much more gloss than standard, due to the helicopter tape applied.
