Probably diesel sludge (gelling) due to low temp , should work ok once it warms up , give it a try on the way homeI don’t know what the lowest was, but it was a fresh -7.5 at 6am when I left for work.
Not the best start to a morning, the parking heater didn’t fire up for some reason & half my heated screen isn’t working due to the huge cracks in it.
I use a Diesel additive to increase Cetanes in situations like this. The one I use is from Liquimoly.Probably diesel sludge (gelling) due to low temp , should work ok once it warms up , give it a try on the way home
I liked your post, but don’t like the situation!I don’t know what the lowest was, but it was a fresh -7.5 at 6am when I left for work.
Interesting. I have a full tank of the premium diesel as I do this every 3 months.I asked AI:
In sub-freezing temperatures, diesel fuel can undergo several changes that can affect its performance. One of the main issues is the formation of paraffin wax crystals, which can give the fuel a hazy appearance and eventually clog fuel filters, blocking the flow of fuel to the engine
3
. This phenomenon, known as gelling, can cause the diesel to become non-combustible and can plug filters
5
. The temperature at which diesel starts to gel is typically around 15ºF or -9.5ºC
Another issue is the presence of water in diesel fuel. Water is almost always present in diesel fuel to some degree and can freeze in cold temperatures. Frozen water can clog fuel lines and fuel filters, starving the engine of fuel
2
8
The exact freezing point of diesel fuel can vary widely due to the different hydrocarbons it contains. The temperature at which diesel freezes solid in lines is called its pour point
. However, the pour point is usually lower than the temperature at which gelling issues begin to occur
To prevent these issues, it's recommended to use fuel additives that can lower the freezing point of diesel fuel and remove water from the fuel system
. Switching to a winter blend diesel fuel when temperatures start to drop can also help prevent cold weather diesel problems
7
Is the premium have a lower freeze delta ?
More likely to be me pressing the off button than the on one whilst half asleep.Probably diesel sludge (gelling) due to low temp , should work ok once it warms up , give it a try on the way home
I'm curious......what is a California Switchbot? ...... do I need one? I might be suffering from a lttle FOMO here........Anybody have the lowest temperature in their California last night ?
Drop them in here, or if you prefer
Answers on a postcard.
What devices / app are you using to record these temperatures.Anybody have the lowest temperature in their California last night ?
SwitchBot WiFi Thermometer Hygrometer 3 Pack with Hub Mini, IP65 Indoor Outdoor Thermometer Wireless, Humidity/Temperature/Dewpoint/VPD/Absolute Humidity Sensor with Smart Alerts, Works with Alexa https://amzn.eu/d/4HVRFg9I'm curious......what is a California Switchbot? ...... do I need one? I might be suffering from a lttle FOMO here........
SwitchBot WiFi Thermometer Hygrometer 3 Pack with Hub Mini, IP65 Indoor Outdoor Thermometer Wireless, Humidity/Temperature/Dewpoint/VPD/Absolute Humidity Sensor with Smart Alerts, Works with Alexa https://amzn.eu/d/4HVRFg9What devices / app are you using to record these temperatures.
I likey.I’m using Ruuvi Tags connected to a Victron CerboGX on my side.
I likey.
So much data.
But any humidity data ?
Nearly 25 degrees!
Toasty!
Bet you’re sat in your shorts
“Work” whilst sat in your shortsI work in my van 4 days a week.
