Coolant behaviour question
kernnowkarmann
kernnowkarmann
Luxembourg
T6 Ocean 204
Hi all, had major service about 3 months ago including new water pump etc.
In last week have done about 2.5k km. Mainly in 3 long journeys from Luxembourg, going to and from alps and today 1k km going to North of England.
Stopped at service station about 200km from destination and when started engine the coolant light came on and it told me to check it. I had checked before first long journey and all fine so was surprised to see it had dropped about halfway down the tank.
Went into garage and bought some coolant. Knowing you have to be careful if engine not fully cool I started undoing the cap slowly. Before it was off it made a kind of hissing sound and the coolant level came back up to normal.
When restarted, no warning! Checked after 100km and coolant still at normal level.
Does anyone know why this would have happened?
Thanks! (And the van drives like a dream on these long journeys!)
A build up of pressure within the coolant system causes pressure expansion of all coolant pipes and if high enough even the coolant radiator thus increasing the volume of the coolant system and hence a drop in fluid level.
Open coolant expansion cap, pressure drops , volume of coolant system returns to normal and fluid level rises.
So, what is causing the pressure to rise in the coolant system?
The coolant system is pressurised to a degree, normally. Coolant as it heats up increases in volume, hence the expansion tank , but not to the degree you mentioned.
It could be something simple or something more significant.
Air lock from water pump change?
Faulty pressure cap on expansion tank?
Gas leak into coolant system?
Had a new water pump etc when cam belt was done .
Indie deliberately over filled (visual on expansion tank) ! Told me the level will drop !
it did back to Normal !
its a thing
I’d get this checked out by a mechanic. The coolant system in a modern car is split into two parts, pressurised and atmospheric. The pressurised part ensures that water doesn’t boil at the working temperature of the engine. The atmospheric part is topping up any water losses via the header tank. It appears you’re getting pressure in the header tank which isn’t right. I’ve not observed the situation you’re describing on any of our vehicles.
Just thought I'd share the video of what happens when cap removed from coolant. This is with a cold engine a day or so after last used
Update:
Fixed, was the EGR coolant pump (might not be the correct terminology, struggled a little with the translation...)
Still, expensive at a tad under €2000
Windscreen developed a massive crack though so at least that got changed as well, love a new screen without all those tiny chips... (looks on the bright side and tries to ignore engine cost)
Update:
Good to have your update, it could help others in the future. Sorry it’s been an expensive solution though, but at least you have some peace of mind now.
Update:
If you don't mind me asking - at how many kilometers did you have to change the EGR pump? Also, hope they changed both the EGR cooler and the EGR pump. Looking at the cost it seems they have done both. I think it comes as a single unit.
Sent from my Pixel 6 Pro using Tapatalk
The van has done 72,000 km. The problem first occurred about 5,000 ago though, I did 5 long (750+km) journeys topping it up before I could get it fixed, in this time it definitely started to get worse though
I am at 51000 and got an egr error. Now it is gone, but will replace both EGR cooler and pump in the next few months.
Hiya,
I’m having a similar-ish problem with our 2007 Cali. The coolant light was coming on as you describe, and there was also oil residue in the tank. Local garage changed the tank and sensor in case the sensor was faulty and also changed the oil cooler.
Problem is still happening. Release the cap, level goes up to normal. Start driving, light immediately comes on. Engine light has now appeared. Garage suspects it’s the head gasket and won’t go any further so they’ve given us the number of someone who will (lee woods in Chingford) but so far haven’t been able to book it in with him as he’s too busy and seems reluctant…. Any advice welcome! And any other leads on good specialist mechanics east London area appreciated!
Thnx
Hiya,
Thnx
Get the EGR cooler checked for leaks before arbitrarily changing the head gasket.
Thanks for getting back to me - Yes the garage already changed the EGR cooler - if this is the same as the oil cooler? They called it the ‘engine oil cooler’, they said it had been replaced previously and one of the threads was damaged…
This is still an ongoing problem with our Cali if anyone has any thoughts? We’ve taken it to a specialist now, who is a bit mystified as to why it’s happening!
To recap - pressure builds up forcing coolant level below sensor probes, sensor light comes on. Release coolant cap, coolant level rises back up, no drop in level. Happens every time we drive.
Heater works fine, never overheats, so don’t think it’s the head gasket.
Have had the engine oil cooler changed, so it’s not that.
Thanks!
Thanks!
To my mechanical mind it has to be either the head gasket or a minute crack somewhere. Clearly high pressure is building up inside the system, which can either come from a pump or a piston. I'd say a mini crack in the gasket is causing the pressure to leak into the water system. It wont be oil, you would see, so all that is left is the pistons. Could also be a pump elsewhere, but I'm not intricate with the T5 system. Have they done a piston pressure test? Is it more It's not the HG because you don't want it to be? General fault that causes this are overheating of the water, which you say is not happening, or a HG issue.
hiya, thanks for responding.
Sorry I didn't mention that there is oil residue in the coolant tank - which is why we had the engine oil cooler changed. Since the change there is still some oil in the coolant, but the mechanic doesn't think it's enough to be a leak, more likely just residue left in the pipes. (i've attached a photo - this is where the level goes down to when the pressure builds up, you can see the dark colour caused by the oil residue)
I will ask him about a piston pressure test
The mechanic said he doesn't think it's the HG because the car is not overheating and the heater works as expected.
thank you!
Hiya, hope everyone has had good festive break and happy new year!
We’ve now had a garage confirm it is the head gasket that’s gone, so not good news but good to know at least! They did a simple test with a liquid, I’ve no idea why no one else that we’ve seen didn’t do that!
Anyway now looking for someone to fix it so any contacts in the London area would be great or even further afield is fine too!
Could you pass on their details? Think we might have to venture a bit further.. thanks hannah
Happy to.
AVS in leatherhead - Dave is the owner.
01372383038
If he doesn’t have capacity come back to me and there’s another place who just did my clutch who were also good and not much further.
Is Huntingdon too far? I’m guessing yes? Highly recommend Adrian Beer at Mill Garage, Beer of Houghton.
