SusiBus
2-pedal power Peppa Pig trike
Agree, the latter.
It’s the latter I’d guess. But the Multivan eHybrid loaner had a graphic on the infotainment screen showing the underfloor batteries sending power to the rear wheels, so I’m guessing that too is 4wd in Hybrid mode. Wonder what the “new system” is then? Maybe just bigger batteriesWhat I’ve yet to understand is if there are 4 electric motors powering all 4 wheels or just the rears with the 1.4L ice powering the fronts.
What happens after 30 + miles. Do you lose the 4 wheel drive system?It’s the latter I’d guess. But the Multivan eHybrid loaner had a graphic on the infotainment screen showing the underfloor batteries sending power to the rear wheels, so I’m guessing that too is 4wd in Hybrid mode. Wonder what the “new system” is then? Maybe just bigger batteries
I would assume the ICE is charging the battery. Otherwise what’s the point of a quasi AWD system. It needs to be operational whenever it’s needed.What happens after 30 + miles. Do you lose the 4 wheel drive system?
why not keep the table stored inside the sliding door as in T6/T6.1 , which can also be used inside/outside and does not take up valuable space in the boot. You can access it from inside too without leaving the car and opening the boot in winter/rain.Ah. The outdoor table stored in the boot can in fact also be used as the indoor dining table:
So it’s not as silly as it looked in the first videos. You don’t just get a tiny indoor table. There a tiny indoor table + an indoor/outdoor full-side table.
That was my understanding too, several pages back, from having seen other brand YouTube reviews.Yes, you do lose the electric power and it just reverts to the petrol engine automatically. The car does do a little bit of brake regeneration while driving to put some charge back in the batteries but this charge is only then used when moving off from a standstill (it’s pretty quick!) But it doesn’t recharge the batteries per se for pure electric driving - you have to plug the car in to a charger for that.
I borrowed a 230v home charging lead from a friend, it took 7hrs to fully recharge the batteries - on a dedicated 7kw home wall charger it takes 2hrs.
Think I'll keep to my original decision. Tsi.Yes, you do lose the electric power and it just reverts to the petrol engine automatically. The car does do a little bit of brake regeneration while driving to put some charge back in the batteries but this charge is only then used when moving off from a standstill (it’s pretty quick!) But it doesn’t recharge the batteries per se for pure electric driving - you have to plug the car in to a charger for that.
This is what I thought as well, but as it turns out, there is a solid reason. The Multivan has reinforcements inside the sliding doors to give passengers better protection in the event of a crash. The space just isn't there anymore for the table.why not keep the table stored inside the sliding door as in T6/T6.1 , which can also be used inside/outside and does not take up valuable space in the boot. You can access it from inside too without leaving the car and opening the boot in winter/rain.
Sounds expensive and complicated if it goes wrongI believe it’s the latter
Most, if not more of that, seems to be the longer nose and windscreen, not in the living area unfortunately.It’s 27cm longer than the T6
Whilst the Ice is working it is also charging the EV batteries via the high power output alternator.That was my understanding too, several pages back, from having seen other brand YouTube reviews.
I believe the new Defender PHEV is similar - nominal regen, but once the battery is drained it’s dead-weight til you’ve charged it again on mains.
The novelty of full-electric trips would no doubt wear off, so I’m interested in what real world battery life is like using it only as hybrid boost supporting the petrol engine.
That would be best case scenario. Makes no sense getting phev for a campervan that’s away from home base with such minimal bev only range. I rather not spend my hols searching for charge stations or being obliged to find campsites with electric hookups. Relying on the 1.4L ICE to pull a ~3t vehicle is less than ideal over long distances.Whilst the Ice is working it is also charging the EV batteries via the high power output alternator.
That would interest me as well. My thinking is that the rails are already in place and the seats exist, so why not? The answer is probably payload limits, which according to the VW presentation, is "similar to the T6.1 Ocean" and around 360Kg. However, 5 passengers at 70Kg each (the driver is included in curb weight) and the 2 extra seats add up to 350 + 50 Kg. This could be a problem with registration and insurance. The best solution in the VW universe is probably a Beach Tourer with after market kitchen units for when you actually need them.Not all negative though….I like the easier removal of seats and bed to make a useful van … Does anyone know if it possible to add two extra travel seats in the new ocean? having a six seater when not camping would be handy.
The fact you only need one rear seat to make the bed would give more roomPlenty of room for a porta potty. You will need to be quite flexible.
Toilet yoga…
#vwaheadofthegame
Why not diesel?Think I'll keep to my original decision. Tsi.
The registration document will dictate the maximum number of seats. My T6 Beach has the 2-seat bench, but it is still classed as a 7 seater. Would take a lot of reconfiguration to achieve that though!That would interest me as well. My thinking is that the rails are already in place and the seats exist, so why not? The answer is probably payload limits, which according to the VW presentation, is "similar to the T6.1 Ocean" and around 360Kg. However, 5 passengers at 70Kg each (the driver is included in curb weight) and the 2 extra seats add up to 350 + 50 Kg. This could be a problem with registration and insurance. The best solution in the VW universe is probably a Beach Tourer with after market kitchen units for when you actually need them.
It takes me about five minutes to take out the storage units on my 2-seater beach. i then add two more single seats and i have a six seater in less then 10 minutes. Changing the two seat bench to a three seater would be a bigger job though. those things are very heavy.The registration document will dictate the maximum number of seats. My T6 Beach has the 2-seat bench, but it is still classed as a 7 seater. Would take a lot of reconfiguration to achieve that though!
This extra length means it won’t fit in my garage so it’s a no from me.However much I try to like the new Multivan California, I keep coming back to one snag…
It’s 27cm longer than the T6. That may not sound a lot, but for on-street parking in London it makes quite a difference. It will also overhang car park bays by another 27cm more than the T6, which already sticks out a bit, although you can still get away with it.![]()
longevity for me - ‘feels’ more likely the legislation will restrict diesels sooner?Why not diesel?
Do you really think the Euro6 diesel is going to continue being exempt in All the LEZ zones, and in London and elsewhere ANY diesel attracts a premium parking charge already, but not petrol.Why not diesel?
