Boot Lights
bagel.rhodes
bagel.rhodes
Watford
T6.1 Beach camper 150
Boot lights.
My boot lights will not go off even when closing, shutting down all the internal lights etc. It’s just been in for a service and I think they’ve done something, I know I should probably take it back. I’m worried it will drain the pleasure battery although I do have a solar panel, not much good that is currently.
These seem to be on a different circuit. Any ideas?
Many thanks
Craig
Does your boot looks closed on your instrument cluster?
Don't you have a button for the lights in the boot?
Do you mean the 2 lights in the bootlid?
I have a T5.1, so I don't have those lights, and thus I can't test it for you.
Boot lights.
Many thanks
Craig
There is a switch on the right side of the boot (inside of right C D-pillar) for the lights. Have you tried operating that?
Sent from my Pixel 6 Pro using Tapatalk
This video explains vehicle lighting…it should help you understand what should be happening, handy if you need to take it back to the place that did the servicing?
At around 5 minute 50 secs there is a mention of the tailgate internal lights.
There is a switch on the right side of the boot (inside of right C pillar) for the lights. Have you tried operating that?
That should be the D-pillar. The C-pillar is between the two side windows.
That was the button I was referring to.
The boot light stays in for a while when you open the tailgate and then switches off
